Question about Linksys WPSM54G Print Server
Installation wizard does not locate the WPSM54G
Installed the WPSM54G following the instructions but when the installation wizard searches for it in the network doesn't locate it after a long time.
both pc and WPSM54G are in the same LAN of a Cisco 831 router and I can see the broadcasts coming out from the wizard and ethernet LEDs of the PS shwos traffic but the wizard does not locate any device
I tried many tests: without the router through a direct ethernet cable, another PC, etc.
Any suggestions ?
  • haalcon May 03, 2008
    Many thanks serra_baby, the printer is HP Laserjet 1022 and I configured the router to accept DHCP requests and the Print Server acquired one, then I checked the IP and pointed it with a browser and finish the installation manually but saving a static IP
    Seems the wizard is not working properly to found devices with 0.0.0.0
    Now I have the print server configured and cannot make it print, but this is another story ......
    Thanks again,
    Novelist:
  • 144 Answers
Hello!
what is the model number of your printer? if your setup cd is not detecting your printserver, try the ff:
-- while pc and printserver connected to the router and your printserver connected to your printer. try to reset the printserver for 30sec. Is it printing? If yes, do you see any IP address on the print out
-- If no, unplug the power for 5 seconds and plug the power back in of the printserver then try again to run the setup cd. you may also check your routers dhcp server table if its detecting the printserver
-- if printserver still not detected ty to connect printserver directly to your computer
-- search if you have bi admin utility on your setup cd and install it on your pc
-- manually assign static ip address on the printserver using the bi admin utility and on the pc
-- if successful, connect printserver and pc back to the router and check if you can ping the ip address of your printserver
Posted on May 01, 2008
I just purchased a new laptop with windowss 7. I can print directly to my epson Stylus Photo RX620 from the laptop, however when I try to print form my print server WPSM54G I get an error message that says no support. Any solution?
Posted on Mar 28, 2011
How can I install WPSM54G on a windows 8 PC
It looks that you would like to install drivers for Linksys WPSM54G.
Please write to us with the answer of the following question.
1) Do you have the driver installation disk with you?
2) Did you try to install the driver?
3) Did you get any error while installing it?
Linksys WPSM54G is not compatible with Windows 8. You can check for the compatibility of any device or software from the Windows Compatibility Center. Please refer to the link given below.
http://www.microsoft.com/en-us/windows/compatibility/win8/CompatCenter/ProductViewerWithDefaultFilters?TempOsid=win8&Locale=en-us&TextSearch=Linksys%2BWPSM54G&Type=Both&CurrentPage=0&TotalPages=1&ShowCriteria=0&SortCriteria=Relevance&Compatibility=Unknown&LastRequested=14
In Windows 8 you can install software in compatibility mode with previous version of Windows. Please refer to the steps given in the link below under the section "Apply a compatibility mode"
http://windows.microsoft.com/en-IN/windows-8/get-apps-devices-working
I hope your issue gets resolved by now, please write if you still face any issue.
Sep 15, 2013 | Linksys WPSM54G Print Server
Show to install sound device driver in windows xp ?
  • 1 Insert your driver disk into the CD/DVD ROM drive. The disk should automatically boot. Then follow the on-screen instructions. This usually entails clicking on "Install" or "Install Sound Driver."
  • 2 Download the sound driver specific to your card and Windows XP. Driver websites include Drivers Kit, XP-Drivers and Driver XP. Locate the make and model of your card. Click on the manufacturer and then select the "Download" link.
  • 3 Double-click on the sound driver. The application will go through a setup process. Follow the on-screen instructions.
  • Manual Installation
  • 1 Click on the "Start" menu. Select "Control Panel," then scroll to "Add Hardware" and click to open. Sometimes, the automatic installation does not work properly. You will then need to install the sound drivers manually.
  • 2 Read and use the "Add Hardware Wizard." Click the "Next" tab. Windows XP will scan your computer for components.
  • 3 Scroll down the list to "Audio Drivers" or "Sound Drivers." Then click "Next." Select the "Finish" tab. Another window will appear.
  • 4 Select the "No, Not This Time" option on the "Hardware Update Wizard." Click "Next." Choose the "Install from a List or Specific Location" button. Then click the "Next" tab again.
  • 5 Place the sound driver disk in the CD/DVD ROM. Point the "Search Option" to your CD/DVD ROM or download folder. Click the "Include This Location to Search" box. Type in the path to your download folder or select the "Browse" option. Search through the computer to choose your download application. Click "Next."
  • 6 Wait until the file installs. This takes approximately two to three minutes. Turn up your speakers and reboot your computer
  • please rate my service with 4 thumbs up
    Nov 23, 2010 | Computers & Internet
    Dear Team, recently i have re installed os(windows xp) in my Laptop(IBM R50e-thinkpad). after installation its not showing any network adapter in the device manger. Please let me know what to do..
    just click the start button then choose control pannel then the add hardware the wizard will now then search the hardware that is not installed after searching the wizard will now ask you to install the driver for the hardware insert your driver disk and follow the wizard instruction..good luck hope this helps
    much appreciated if you click the 4 thumbs up button for my answer on your free question this helps me keep going
    Sep 10, 2010 | Gateway GT4024 PC Desktop
    Audio driver sigmatel not installing automatically installed in windows xp my dell CD are creak and i can't installed my audio driver my Audio driver "sigmatel-9751"
    Well if you have the drivers, please follow the instructions; Go to device manager.. Right click on the "My Computer" - "Manage" and from left pane, click "Device Manager" check if there's any "Yellowed" on the left pane, if so right click on the yellowed link and "Update driver" a new windows "Found New Hardware" wizard will pop up. Select "No, not this time only" and next, select "Install from the list or specific location" next - Tick mark "Include this location in the search" and Browse the driver to the location/directory where you saved it or to your Cd. Click open/Ok and follow the onscreen instructions, if you are prompted with any error message like "Driver digitally not signed" just click "yes" or "continue anyway" and then next. Of if you don't see any yellowed link then go to "Sound, video and game controllers" There it should be, follow the same instruction as mentioned above from "Right click on the yellowed link." Good luck. Thanks for using FixYa.
    Jun 05, 2010 | Dell Latitude C610 Notebook
    Will not load
    Open up your PC. And from the windows menu, left Click to open, Settings, Control panel, and the Add
    Hardware wizard. From the Add hardware wizard, install your ASUS hard drive. Just follow the instructions. If you get it installed, then it a job well done. Most of the time, Asus is a supported item of Windows XP, Vista, & 7
    However, if you are prompted to have your own CD to
    get it installed. Just have your download from the
    Internet. Just type at the Search engine blank (Free
    download Asus (90N804SH021) Hard drive software
    installer). Once you have your download, go back to
    your PC menu. Click open, the download and follow
    the instruction to have it installed. Then, have your
    test on the Asus harddrive.
    Nov 28, 2009 | ASUS (90N804SH021) Hard Drive
    Can't connect to WPSM54G after configuring it
    hi sir,
    1. first reset the printserver
    2. make sure that the printer drivers are installed on the comp.
    3. use a w/l comp on which we can go online
    4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
    5. put the print server cd into the comp and run setup.
    6. make sure printer server is near to router and there is no firewall on the comp.
    7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
    8. follow the wizard
    9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
    10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
    11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
    12. if u dont knw, u can ask the comp vendor.
    13. plz also confifm that the printer is compatible with ur print server.
    thanx and regards
    sukhiii
    Apr 16, 2009 | Linksys WPSM54G Print Server
    Cannot see WPSM54G wireless router after configuring it correctly.
    It's pretty sad. This device doesn't support Mac and apparently it doesn't support Windows either! I expect a lot more from Linksys. It seems like this is a common problem yet they offer no clear solution on their web site. Do you think maybe Linksys is going out of business and isn't going to support their products anymore?
    Apr 13, 2009 | Linksys WPSM54G Print Server
    Install disk
    Hi!
    There u go!: http://search.lexmark.com/printer/US/en/19M0000
    You find the drivers in the midle of that page, select your OS and download the needed drivers
    Good luck
    Nic
    Mar 23, 2009 | Lexmark X2350 All-In-One InkJet Printer
    I lost my CD installation for lexmark X1185 printer.
    Try searching for the driver on google and write it to a disk.
    Nov 19, 2008 | Office Equipment & Supplies
    Sanyo VPC-s500 i cant get it to install drivers or find them so i can upload pictures to my computer
    The simple solution to this problem is that no drivers are required. This camera is treated as a removable (secondary) drive just as if it was a USB thumb drive or external hard drive.
    First go to settings on the camera by rotating the dial to the wrench icon.
    Turn the camera on and select Set-Up 2
    Select USB
    Select PC
    Your camera is now ready to use with your computer.
    Now plug your camera into your computer and check under My Computer for the drive to show. You can now copy files over to your computer from the camera.
    If the drive isn't showing you'll have to go into Disk Management to view it
    Disk Management is under Administrartive Tools located in your Control Panel (or Start Menu if you have it set to show there)
    Select Administrative Tools
    Computer Management
    On the left hand side click Disk Management (or on the right click Storage then Disk Management)
    Finally you can now Right Click the cameras drive and chose Open
    Sep 20, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
    Linksys WPSM54G Print Server Logo
    1,309 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
