Cracked LCD as far as I know - Computers & Internet
  • Smack30 May 01, 2008
    yes sorry, asus laptop
    Problem Solver:
  • 15 Answers
On laptop?
Posted on May 01, 2008
I need both screens for rca Galileo 11 pro lcd and touch screen
Answer 1:
From your description, the LCD is cracked. The outer glass you described is the touch screen digitizer and it sounds as though this is intact. If it was broken, even with the LCD visibly cracked, you would see that it was also broken. A similar question was asked in the forum titled, How do I replace a cracked screen?
In reviewing that post, the first answer indicates that the digitizer can be replaced independently from the LCD. Upon doing a search on Amazon for the LCD itself, I did find one listing that you could use to purchase it separately. However, the disassembly video in that post was focused on replacing the digitizer.
I found a similar video on Youtube, titled RCA 10" Screen Replacment - Disassembly - RCT6203W46 PRO, which may be more relevant to start from the back and work your way to the LCD. This video goes as far as replacing the digitizer, but you'll just need to remove the LCD and the respective connections and attach the appropriate ones to the new LCD.
Furthermore, I did a search on eBay and discovered that there are two versions of the LCD. One that is a straight lcd cable and the other that uses an l-shaped cable. It is important to purchase the correct one. This ebay listing is specifically for the straight cable, but the seller also sells the l-shaped cable as well.
How do you know which one your tablet has? You may need to disassemble it to find out, as there was no specific documentation that I came across based on the model number or manufacturing date that indicated a specific way to know. You could try contacting RCA support, but disassembling helps confirm it before you decide to order from eBay, Amazon or any other third party.
Answer 2:
https://www.google.com/search?q=I+need+both+screens+for+rca+Galileo+11+pro+lcd+and+touch+screen%3F&rlz=1C2GIGM_enUS766US766&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwi6rqjt6IXXAhWKQCYKHUNvBNcQsxgIKA
Oct 22, 2017 | RCA Computers & Internet
Repair Problem
HI Otis,
I repair LCD Screens in Playstation Portables all the time.  If I can find a replacement case for your garmin I know I can do it.  Give me a little time to locate what you need as far as parts. Do you need a LCD screen or just a case or both? www.playstationclinic.com
Oct 14, 2007 | Garmin StreetPilot 2720 GPS Receiver
There are lines through the screen (red and blue) like the screen is cracked but the screen s not cracked as far as i can see
If the set got struck on the screen the screen itself may not be cracked but the panel (The entire front where you view the image is called a display panel) may be damaged inside.
A good photo would tell me--usually it will look like a odd burst or lines and or colors more pronounced where the screen was hit and spreading out in a uneven pattern---Google for "Pictures of Damaged LCD or Plasma screens"
Dec 06, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My television's LCD screen is severely cracked. Where would I look for a replacement?
I would highly recommend you recycle the tv or sell it on Craigslist or Ebay for parts. Usually it will be cheaper to buy a new set vs. replacing the screen
Apr 10, 2012 | Philips 32PFL3403D/27 32 in. LCD TV
My 59"samsung LCD 3D tv
The panels with far exceed the cost of replacing the TV in almost all cases. The panels are usually not available for replacement as well.
Jul 25, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
Cracked screen. where to purchase?
as far as i know, they dont sell lcd screens.. but you may try to call sony's parts center
800-488-7669
Mar 03, 2010 | Sony VGNCR220E/W VAIO CR Series Notebook
A CRACKED PANEL OR SCREEN
heres the part number, i personally get parts off of ebay they ppl selling parts for this tv, i have had no problems so far with any of the suppliers. R1LK460D3LZ10Y N J 46V LCD Panel Module Unit (LC-46D62U
good luck
Jul 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LG Flatron L1710S 17" LCD
From your description, te LCD is cracked. Generally, scratches do not grow, cracks do grow.
A crack in an LCD panel is not covered under warranty, so you'd have to pay to have theLCD panel replaced (Normally a couple hundred bucks)
Oct 11, 2008 | LG Flatron L1710S 17" LCD Monitor
Lcd monitor cracked
Hi
You can probably find an LCD or a defective camera with a good LCD online for fairly cheap. Don't bother trying to buy the LCD new from a local repair shop or store, if anybody has it they will want far too much money for it.
I can list it in our store, though its a special order item and we don't have any in stock at this time. We are an AFFORDABLE digital camera repair business, (Google: Darntoothysam) I can list your LCD for about $45.
If we can help please let me know. Good luck from Darntoothysam com
Thomas
Oct 08, 2008 | Samsung Digimax S630 Digital Camera
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
