Question about JVC HRXVC29 DVD Player/VCR
Problemin vcr when put vcr in play mode run 1.11 and stop and turn off and when use modo rew o frw is de same problem you can help me
  • 27 Answers
May be one of these factors, dirt on pinch rollers, tape itself, take up reel,pls chek all these factors and post comments
Posted on Jan 22, 2012
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Tape stuck in VCR
With care, it is possible to retrieve the tape. VCR housings are held on only with a half-dozen screws and once those are removed, you will be able to see the transport. If the tape itself was defective (it only takes a stretch of tape with finger oils on it) then you will see it wrapped around several things with the worst of it around the drum itself.
The transport, if its control electronics has died, can be operated by hand once you have the tape free and laying loose so that you can manually eject the tape.
If you have made it that far, you will have a cassette with a long loop of tape dangling out.
On the bottom of the cassette is a hole a little larger than a pencil in diameter and you have to use something like a pencil stuck in the hole to release the brake. Once released, you can turn the takeup reel from underneath and wind the tape back into the cassette.
Unless the VCR is totally dead, I would take another cassette, one that isn't important to you, and see if that one will load while you watch the mechanism. If it loads and can be ejected afterward, then the first cassette was at fault in the jam.
DON'T touch the surface of the video head unless you clean it throughly with a soft cloth and some window cleaner afterward.
Posted on Jan 05, 2009
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
Alguien abla espanol?
Hola si..aquii yo hablo espanol; si es que existe el codigo en el dish book, hazlo en el modo de vcr, ahi te funcionara, no lo hagas en el modo de tv por que no te va a obedecer.
Alguna pregunta extra, aquii estare.
Gracias.
Aug 11, 2009 | Broksonic SC975 19 in. TV/DVD Combo
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Can't record through A/V cable
make sure camera has this function first,Easy way to check is to see if top of camera has a record botton where play,ff,rew,stop are..Put camera in VTR mode then hok up cable to tv ..if no signal is comming thru,, check on camera menu for this function..LINE IN
Dec 07, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
VCR stops playing
A couple of possibilities: the bad electronics unit might have power supply problems, optical sensor problems, or other problems with the electronics. If you have some tech savvy and a voltmeter, you could check the power supply voltages. This circuit is likely in the close vicinity of the fuse. On the output side you should see a +5 volt, +12 to 15 volt, and perhaps a -35 volt (approx). The +5 supplies the logic circuit, +12 the motors. If these voltages are missing, or way out of tolerance, you will have a dead unit. A frequent cause of problems in the supply is bad electrolytic capacitors, especially in the older units (Panasonic manufactured rigs, late '80s/early '90s). Possible values on these capacitors: 2200MFD/10V 1000MFD/16V and several others. Replacements can be supplied by MCM electronics, Mouser electronics. I use the Panansonic FC series from Digi-Key Electronics. Sensor problems: Many VCRs have the sensor opticals mounted on the main circuit board, and locate themselves in particular spots in the mechanical section. One or more sensors detect tape loaded, one each for the supply & takeup spindles. If any of these sensors (especially the supply/takeup sensors) are non-working, the logic circuit will detect an error condition, and shut down the unit or at least put it into a stop mode.
Sep 28, 2007 | Sony SLV-998HF VHS VCR
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Rewind or fast forward
Though not familiar with this model, VCRs of all sorts have an idler mechanism which drives the supply and takeup spindles. Either the idler is somehow defective and slipping, and, assuming this idler is belt driven, the belt may be slipping just enough to cause a no Rew/FFW condition. If you had access to a test tape jig (a clear dummy tape, which allows a tech to view what is happening in the area normally obscured by the loaded tape), this might give a clue as to what is happening. On alot of machines, a problem with Rew/FFW would also mean a tape takeup problem in standard play, result in tape spilling out inside the machine. Sensors would catch this condition and go into a error mode, as yours is doing. One other thing which might be happening here, is the pinch roller not being disengaged from the capstan in the Rew/FFW modes. I think this is where I'd look first, and you can probably see if such is happening just by pulling the cover off the VCR. The pinch roller is just to the right of the rotating video head. In the play and forward/rev search modes it will press the tape up against the capstan (a rotating shaft). When in Rew/FFW, the pinch roller should be pulled back from the capstan, maybe 1/4 inch or so. Whatever the case, repair will likely take someone tech savvy. Costs might not be economically justified, with the low-cost, disposable rigs sold in the last 10+ years.
May 29, 2007 | Sanyo VWM-950 VHS VCR
Vcr plays ok, but will not rew or ff
either bad mode select switch or bad sensors. my bet would be bad mode switch( pull apart and clean contacts.)
Mar 07, 2007 | Panasonic AG-720 VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
JVC HRXVC29 DVD Player/VCR Logo
20 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
