Question about Intel Motherboard
Power supply and RAM aslo working but display is not comming?
When
  • dio dcs May 11, 2010
    more details please
  • 52 Answers
It means there is no dispaly in your monitor. can you listen any beep tone. did you change the setting for your motherbord. in my view you have deactive the Vedio Share memory. so plz reset your bios.
taking your our battery from the motherboard. and reinstal the battery. i hope it work fine
thanks for your question.
Posted on May 16, 2009
    Genius:
  • 1,011 Answers
Sir,
Reinstall the mother board driver
ok
bye
Posted on May 09, 2008
Power but no display
Change your RAM and then check the power supply is working correctly. A failed lead in the power supply can give the symptoms you describe.
Jul 22, 2013 | Intel Computers & Internet
CES GF 7050 can't boot
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=858&MenuID=16&LanID=9
I think your harddrive is failing.
Try to borrow a harddrive from a friend, just to find out of the mainboard is failing.
The power supply, could have a fault, try to renew that.
But one of the ram modules, could also have a fault.
Try to boot with only one module.
Look aslo at this page here:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Any beeps at startup ?
Here is a list of beepcodes:
http://www.computerhope.com/beep.htm
Best of luck :-)
Jan 31, 2013 | ECS Mcp73t-m5 Gf7050-m5 Motherboard Nvidia...
Intel desk top board no display
- remove all pci card
- check ram ( scrub with rubber eraser and broom ram slot with small brush, or your can troubleshut with new ram )
if still no display
- troubleshut with display card ( New display card )
if still no display
- troubleshut power supply with new power supply or any power supply is still good in condition( working power supply )
if display still not appear and your was do all tip above finally
you must troubleshut your motherboard with all your hardware. but your must use motherboard supported all your hardware.
Jun 10, 2010 | Intel D845GVSR Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
No display
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 | Acer 22" X223w LCD Monitor
START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Please rate solution if it helps.
Jul 20, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
No output on Monitor
Check if any of the pins of the Keyborad PS2 jack. Looks loke during cleaning a few vital parts may heve moved. Unseat the RAM sticks and after cleaning insert it firmly. Check all cable and wires for snug tight connections. You could try to clean ur power switch too bt aerasol spray, but the main is the keyboard. Recheck for bent pins and/or any stuck keys on the keyboard. If evrything is OK and the PC still behves the same, try replacing the power supply (SMPS) with a properly functional one & if it works, simply buy a new SMPS and install it....sodeep
Apr 13, 2009 | Intel Desktop Board D845GLLY Motherboard
Power,but nothing on screen
refix your ram after clean dust from it. aslo reset your bios settings,remove cmos cell for 15 minutes.then check.
Jan 04, 2009 | Intel Motherboard
No boot
Check to make sure you don't have any extra standoffs under the motherboard that may be shorting it out.
Nov 02, 2008 | Intel DG965WH Motherboard
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Intel Motherboard Logo
133 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
