We have Insignia 19" LCD TV/DVD combo. When a DVD is played, the DVD will only be shown for the furst half of the movie or series. Is this a comon situation? Wheat is the best apporach to take care of the problem. We have tried a veriety of DVDa adn the same situation was found. Also, we have clearn the disks. Thanks, Sheila
    Guru:
  • 1,894 Answers
Did u try a clening disk?
Posted on May 01, 2008
  • dewan nafees ahmed May 01, 2008
    first of all i am not able to get ur question clearly.. please say ur problem clearly.. ter r a lot of spelling mistakes in ur last post..
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
I have an Orien FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
Black box in middle of screen
that is probly the closed captio is on get to your menu and turned off..
hope that help
Apr 12, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
DVD player died during movie. When disc is inserted the player makes soft 'whirring ' sound - but alas no picture/no audio. Tried several different discs. Same result. HELP!!!
Sorry, but it sounds like the DVD player is just gone. You can attempt to have someone repair it, but with the low cost of new DVD players, it probably isn't worth it.
Jan 10, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
I have the tv/dvd combo- the dvds keep ejecting and won't play. I have had this problem for some time- the tv is less than 1 year old.
try while tv is playing unplug it to reset it,, if that dont work your belt or head on player bad or need lining up
Aug 12, 2009 | Insignia NS-LCD19 19 in. LCD TV
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Program Remote
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Feb 05, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Mickey TV/DVD combo movie problem
When you press Play, do you see that shown on the screen? If there are extra inputs to the TV, make sure that you aren't switched to one of those. SOmetimes they're called A/V 1 or something like.
Hope this helps, and please rate my advice, good OR bad.
Good luck!!
Feb 05, 2008 | Disney DTD1363-CAR 13" TV/DVD
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
