Question about HP Pavilion zd8000 Notebook
Why do My HP zd8000 adapter keep making ticking noise?
  • Spoty May 01, 2008
    Thanks How to I do Better repair?
  • Spoty May 09, 2008
    Do You know where I can buy a new adapter? Or Where Do can I order the adapter?
    Scholar:
  • 144 Answers
Normally its shouuld not make.That mean there is internal loose or shot circuit. Better repair or change it fast, cos this can cause more serious problem to your notebook.
takecare.
Posted on May 01, 2008
  • Technocom
    Technocom May 01, 2008
    I mean send it to a place that can repair (in my country some shop do repair old adapter) or best is to buy a new one.
    ** personally i recommend to buy a new one and test it first.
    incase you test and you still have the same sound then its a problem from connecter inside your laptop that is causing it.
    takecare
  • Technocom
    Technocom May 09, 2008
    use your IE and type www.google.com
    and in the search box just type
    buy notebook adapter
    + the place or country you're in
    like this one
    http://www.lindelectronics.com/
    takecare.
How to update BIOS on my HP Pavilion zd8000 laptop running on Windows Vista Ultimate
visit HP's site, http://www.hp.com/#Support enter your system details then download bios. after downloading the bios. close all open programs. remove any external device. make sure ac adapter is connected. then run the bios update. that should do it. =)
Jan 07, 2010 | HP Pavilion zd8000 Notebook
My ZD8000 went off and will not come back on. First I thought it was my AC adapter b/c I had it do it before and I replaced the AC adapter and it was fine, but I got a new adapter and still it will not...
MOSFET on the front end behind the DC Jack is open. Usually an AO4407 (alpha and omega -30v 12a ) or FDS4435(fairchild -30v 11a) This will keep all voltage from going into laptop.
No power indicator
No charge indicator
No response to power button being pressed
Oct 03, 2009 | HP Pavilion zd8000 Notebook
HP zd8000 will not boot on battery
If every thing is correct ( the Battery, the AC adapter, etc ) then also the Power light is not turning on, then somewhere the power is not transmitting. The laptop must have a internal connection Breakage. Oh, I saw that you didn't mention AC Adapter. Have you checked it. Also check the the Control Board of the Laptop. Better you give it a Servicing.
Thank you Sir, Have a nice day.
Sep 25, 2009 | HP Pavilion zd8000 Notebook
Hp zd8000 wont turn on...
hi thanks for using fixya!!
Try first to remove the battery and connect the AC adapter to your laptop, you will use the power supply directly from the AC adapter without the battery. Turn on your laptop, then if its working normally as it should be,
Then try now to install back the battery then connect the AC adapter, turn it on. If still does not work, perhaps you have a problem with the battery.
If you need further assistance, let me know.
May 24, 2009 | HP Pavilion zd8000 Notebook
I can't start my hp zd 8000
If no power check;
  1. If on battery take out battery and plug in ac adapter to a known good outlet.
  2. Make sure power connections are snug
  3. Make sure ac adapter connections are good.
  4. If ac adapter on power strip, turn off and on power strip
  5. Try again.
If theres no display try the following;
  1. Reboot and keep tapping on F8 to go to Safe Mode.
  2. In Safe Mode select "last known good configuration" and then press Enter
Still no display;
  1. Connect an external monitor, toogle to external monitor
Let me know if any these solutions work if not we can try something else
Jan 18, 2009 | HP Pavilion zd8000 Notebook
Battery or power cord problems
Problem sounds like the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Dec 17, 2008 | HP Pavilion zd8000 Notebook
Power Adapter
http://cgi.ebay.com/AC-Adapter-Power-Supply-for-HP-Pavilion-zd8000-zv6200_W0QQitemZ320256942042QQihZ011QQcategoryZ31511QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jun 01, 2008 | HP Pavilion zd8000 Notebook
Adapter
there may be some loose connections inside your adapter. change the same.
May 01, 2008 | HP Pavilion zd8000 Notebook
HP ZD8000 won't come on
Try to change the RAM and see if that helps the beeping. Normally, repeating beeps mean bad RAM. Not sure what the problem is with the disk drive, seems to be a mechanical problem. Thanks, Lolita
May 15, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
