Warrenty How do I find out if my computer has a warrenty??
    Problem Solver:
  • 14 Answers
If you contact your computer system's manufacturer, they can determine the warranty status for you quite easily based on the system's model number and serial number.
If you don't have contact information for your system's manufacturer, simply visit their website, which can be found easily through any search engine, and find their "Contact" section. Usually the technical support department would be the best point of contact for warranty information.
If you like I can look up the contact phone number for you if you can provide me with the brand of your computer.
Thanks,
Geek Squad Agent Erik
Posted on May 01, 2008
Microwave works but wont heat up ?
Please post in the correct section, and possibly have the device serviced under warrenty. If not under warrenty buy a new one.
Oct 05, 2013 | Computers & Internet
M26gtm-35p
cHECK THE PROCESSOR HAS THE WARRENTY IF THE WARRENTY IS THERE RETURN TO VENDOR. IF WARRENTY WAS NOT THERE THROUGH IT .
May 10, 2011 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Attempts to run, then stops. Wont show on my computer that the drive exists. Usb white light comes on then off
Do not take this apart or even open it unless it is out of warrenty. With the model you quote I doubt it is out of warrenty - take it back to where you purchased (with receipt) and get it looked at under your warrenty (free)
Once you open this up you have voided the warrenty so exhaust that option first and then we can help if that route is no good :)
Nov 03, 2010 | Western Digital Passport WDXML800UE...
My touchpad in my toshiba computer is not working. i purchased my computer two months ago. what should i do
You are still in warrenty, go to Toshiba website and get to customer services. Also - as its under 3 months you could take it to where you purchased it from and they should sort it, dont let them tell you to go to the manufacturer as in the legal sense they have a duty to you as you purchased from them and it's been under 3 months.
DONT open it up or let any technician open it up while its in warrenty, that will void the warrenty.
Oct 29, 2010 | Computers & Internet
My daughter has a new ASUS Eee PC 1005HAB, and after a couple months use it will no longer power on.
Try this >>>>
Remove AC power and take out the battery.
Plug the AC power back in and see if it will switch on. If it does shut it back down again and re-insert the battery. Try turning the computer on.
If you get no life from the computer either with or without the battery then this computer has to be sent back to Asus for repair or replacement as there will be still warranty on the computer.
Regards.
Jul 15, 2010 | ASUS Computers & Internet
I TURN OFF MY LG MONITOR AND THE NEXT DAY WON'T TURN ON
If it gradually comes on or does after a while then there are parts that are failing inside. These are usually capacitors and while cheap the labor isn't. So you need to carefully check if you have any warrenty. The cost to fix may be $100 but a replacement can be $100 so unless you have warrenty time to get a new one (it comes with a new warrenty too ;-])
Mar 23, 2010 | LG 22" FLATRON LCD Monitor
When my sansa died for a long time, i just now found the charger and now it wont come on. how do make it come on?
Try charging overnight. Then do a 'reset' by holding the 'on' slide up for at least 20 seconds. If that doesn't work, connect it to a computer with the USB cable and see if the computer 'sees' it as a drive. If none of that works then contact Sansa. Pray it is in warrenty (1 year). Sansa will replace defective players in warrenty but has NO repair option if out of warrenty. I've had two players just quit working (no power at all). One started working again for a while. I was able to replace one (in warrenty) the other is out of warrenty. Seems Sansa Clips have either a battery defect or more likely a connection to the battery/power circuit that breaks. No user fix I've found. Good luck.
Mar 03, 2010 | SanDisk Sansa Clip MP3 Player
Windows won't auto up or go up that 1/2'' when you close door
Because you had it back to the dealer for the same problem whilst it was in warrenty,the warrenty is still valid.Its called a warrenty ongoing problem.The dealer must fix the problem and if you run into problems ask the dealer for the manufacturers warrenty complaint number.They will probably try a bit harder to fix the problem because it puts a blotch on their dealership if you complain to a higher level.Don't let them NOT fix it.Hope this helps
Oct 24, 2009 | 2006 Ford Mustang
The screen wont show the whole words of the 1gb mach speed lyric
If you have a 2 year warrenty, then you should be able to get a new one.
Jan 12, 2009 | Mach Speed Trio Portable MP3 Player
WE WANT THE WARRANTY DETAILS
1 to 3 year warrenty they will give you
in 1 year warrenty if your drive not responding totaly than they transfer to dealer & they will transfer to production house for replace ment
1 more thing if they had say you for life time warrenty than its also equal to 3 year warrenty.
so take care of it.
THNX
May 17, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
