Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Reset the lamp
How do you rest the lamp hours when you put a new lamp in cant find in menu?
    An expert whose answer gotĀ voted for 100 times.
  • 453 Answers
If u don't have a error on screen , no need to do reset
Posted on May 02, 2008
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
I just got a new bulb for my projector. it was fitted as per the instructions, and looked undamaged on delivery, but after about 10 min of viewing, the hight temp alarm sounds and the projector shuts...
Did you rest the lamp hour after replacing the lamp. It is recommended the you have to reset the lamp hour after replacing the lamp. For resetting the lamp hour do the following.
1. Power ON the projector
2. Press the Menu button
3. Select OPTIONS
4. In OPTION menu select Lamp Reset and press the enter button.
(If the lamp hour counter is at the heights level then the projector will turn OFF after some time.)
Apr 28, 2011 | Optoma EP1690 DLP Projector
Reset lamp timer
If you go into the info menu you should see lamp hour meter, should be option there to reset it.
only do so if you have put in a new bulb as bulbs can explode if they go over the hour usage time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Toshiba TLP S30 Multimedia Projector
Resetting lamp hour monitor
It's in the menu under setup or setting.
Mar 24, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
I do not have remote. Church inherited projector.
Thank you for using
FixYa for your problem
  1. you need to enter factory Menu.
    You do so by doing the following:
    1).Start the projector.
    2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
    3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
    Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
    Let me know if this solves your problem.
  2. - Press exit for 3 seconds
    - The Menu to reset the Hours rises up
    - Folow the manual on your screen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | NEC VT460 Multimedia Projector
T V won,t come on and timer lamp on front panel stays lit.
Your lamp hours have expired. Try taking the lamp out then putting it back in. The TV will go to a reset menu for the "new" lamp it thinks that you have put in. From there you can reset the lamp hours from the menu. It it doesn't work, the lamp may be burnt, and you have to replace it.
Aug 13, 2009 | Samsung PCL542R 54" Rear Projection...
Plus UP-1100 Lamp Hours Rest Procedure needed. The lamp is replaced but no menu option for resetting hours and Google provides no answer.
To reset the lamp timer on the Plus UP-1100, turn on the projector, press the menu key, navigate to the power menu, go to the lamp timer, then press and hold the "power on" button on the remote control for 20 seconds - you will see the timer reset to 0000.
Aug 05, 2009 | Office Equipment & Supplies
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Reset lamp timer
Hold the menu button on the TV and menu button on the remote for 5 seconds.The service menu should appear.Select the lamp option and reset lamp hours.
Dec 15, 2007 | LG RU-52SZ51D 52" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
192 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
