2002 Nissan Altima Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nissan march 2003 model japanise make aoutomatic transmission and yesterday the amber/orange light came on and is still on what does this mean
Julio
Level 2:
  • Expert 52 Answers
  • Posted on Aug 16, 2010
Julio
Expert
Level 2:
Answers
52
Questions
Helped
20322
Points
124
You have to get a diagnostic code with a qualify technician. Do not drive your car to far if light is blinking.
1helpful
Nissan K12. Where are the fuses please?
Question edited for clarity.
Question moved to model category.
K12 is the engine. Fuse Boxes are advertised by 'year make model', and that information should be the first 3 words in every question.
The search query for this is simply
year Nissan model fuse box diagram
Nissan Micra / March (K12; 2003-2010) fuses and relays
Fuse Box Diagrams https://fuse-box.info > nissan > nissan-micra-k12-2003...
The fuse box is located under the steering wheel, behind the cover. The location of the fuses in the passenger compartment: Nissan Micra / March (2003.
https://www.google.com/search?q=Nissan+K12+fuse+box+diagram
Nissan march showing U0100 and no engine light
https://www.obd-codes.com/u0100
No engine light because there is no communication. Read post.
Hello. i just got myself a second-hand automatic nissan march ak12 year 2003. can you explain to me how and when to use the transmission '1' and '2' on the gear, apart from the 'D'...
to get the knowledge about your car you can get the help from the company repair and service manual which will guide you each and every thing you want to know and you can get the manual from the given link http://toolsnyou.com/
1helpful
My car doesnt run on the D gear I have to put it down to the 2 to be able to put the car in gear. Thanks My car is a nissan micra/march it is not on the list so i will choose another model
take it to a mechanic, i think the gears on drive are out of place, or the teeth on the gear are worn down so much the gears on the rest of your transmission cannot grab them
It's an engine service light amber in color for 2003 chevrolet tracker? What does this mean and do I need to get it fixed asap?
amber or a yellowish orange color is normal for a check engine light take it to a autozone or a checker oriely's auto parts store and they can run a diagnostic scan on it to tell you what error code is popping up it it is a really major problem the light will be flashing if it is get it checked out!!!
1helpful
Orange exclamation point light comes on
sounds like you might be low on break fluid
3helpful
What does the amber engine light mean on a Nissan Micra, reg 2003
catalytic converter,misfire,oxygen sensor,throttle body,fuel injector,throttle position,iac,egr, gas cap.evap system and a hundred other things can set off the check engine light.running a scan will tell which system triggered it.
Nissan march driver side park light and tail light problem
check the fuses- some car makes uses individual fuses per side. Just saw that in a mitsubishi- I believe Nissan does that too. Those fuses are probably under your hood.
9helpful
2003 nissan altima 2.5s transmission rough shift
Probably sensors! I have already replaced the crankshaft positioning sensor once, nissan replaced it once under recall and now it is bad again! Plus my speed sensor is bad too! Go to any part store and get diagnostic test ran, it will tell what sensors are bad.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
