Question about Epson Stylus CX3200 All-In-One InkJet Printer
I need help with my my epson printer
Hi,I was trying to change my printer cartridge and by mistake I moved the printer head by hand. and now my printer does not work
    Novelist:
    Scholar:
  • 148 Answers
Epson in my experience has made inkjet printers that function BEAUTIFULLY and produce spectacular photo realistic prints. tho when it comes to general maintenance and repair they can be quite touchy.
First start with the simplest things first, unplug it for a while. power it on and perform a self cleaning.
if it wont power on at all or perform a cleaning you may have dislodged one o the drive belts or another one of the belts that contain the sensor strip that tells the printer where the head is.
If you are good with tools resetting the drive belt or sensor strip can usually be an easy task. if not take it to a qualified repair center like at a best buy and see if they cant take a look at it. You may just end up sending it for repair.
One more thing as well to make sure of is that you have the cartridge properly seated and the contacts are clean.
Posted on May 01, 2008
When I open the top of my Epson TX210 printer, the head does not move, so i can't change the ink cartridge
Recent Epson printers does not move the head when you just open the cover - you need to go to the printer menu and select setup menu and then select replace cartridge. Click ok and the head will move to the changing position.
Hope this helps
Sep 13, 2011 | Epson Office Equipment & Supplies
Changing ink cartridge
Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
If you need more step by step instructions, follow this link...
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Mar 08, 2010 | Epson Stylus NX115 All-In-One InkJet...
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
Can't change ink cartridge
Turn on printer, unplug power when head carriage is moving. then, the carriage can move freely by hand.
Jun 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson printer: print head not moving to replacement position
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Jan 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson R380
Turn on the printer. The printer head will start to move to the left; immediately pull out the power cable from the back of the printer. You can now move the print head to the cartridge exchange position by hand. Change the cartridge(s) and close the cartridge cover. Re-insert the power cable, turn the printer back on and it should work OK.
Jan 07, 2009 | Epson Stylus Photo 830 InkJet Printer
Seem unable to get my ink cartridge holder in middle position to insert new cartridge. have tried 2 TR27 copy cartridges from ABITECH Nottingham but both made the error light flash ! Printer id EPSON...
I cannot remember if the Status Monitor (SM) of the 810 has a "change cartridge" facility, but it's easy to check. Right click the printer icon in the bottom right-hand corner of the screen and select printer settings. Then click the maintenance tab - is "change cartridge" one of the options? If so, use it. If it isn't you can download the SSC utility from
http://www.ssclg.com/epsone.shtml
and use this to move the cartridge to the cartridge change position - don't forget to use it to do an ink charge cycle after you have replaced the cartridge.
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Sep 15, 2008 | Epson Stylus Color 460 InkJet Printer
Epson c43sx does not print
change the cartridge thats simple red light indicating you must change your catridge
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Need to change dried old ink cartridge before it says it is out
press the Ink Change button then turn off the printer this will give you the Ink Changing psoition for a long time.
Sep 15, 2007 | Epson Stylus Color 740 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
