Question about Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 fax machine does not have a dial tone
My Panasonic KX-FM220 fax machine does not have a dial tone. I have hooked-up this machine in two different locations. I can copy and print reports on this machine. Any suggestions on how to get a dial tone would be appreciated.
  • Irrigator Jun 06, 2008
    I have the same problem with my KX-FP155. Is there a solution? By the way, it only has one line socket on the back so I'm not hooking it up incorrectly. Have tried other combinations of wires and phones and it's just the Panasonic that doesn't have a dial tone. Is it a common problem - do I need to contact Panasonic (expensive I assume).
  • 88 Answers
Connect a known working telephone to it, if the phone works, your machine needs repair, if not it is a telephone line problem.
Posted on Apr 18, 2009
    Problem Solver:
  • 14 Answers
Is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
Posted on Mar 31, 2009
2 Suggested Answers
  • 168 Answers
SOURCE: Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Posted on May 02, 2008
My panasonic kx-fl501 fax message says please wait and the keys don't work
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Feb 08, 2012 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic Fax model kx FP343 owners manual
no dial tone is coming in the machine, how to set it please
Nov 01, 2010 | Office Equipment & Supplies
Fax machine won't power up
Try pushing the power cord firmly into the back of the machine
Jun 22, 2009 | Panasonic KX-FM220 Plain Paper Thermal Fax
OT OFF SENT REPORT & ON DIAL TONE
Try sending a test sheet using "hook" to a known good fax if it goes the fax is fine (it wont leave the doc feed till its coming out on the rx. fax.) If this works then maybe the speaker is bad or disconnected. As for the report you need to chance the transmission report to off or error.
-Carl, please let me know if this helps.
Mar 21, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Printing report or making copy
Lift up the operation panel and look for debris on the small glass strip.
If that's clean, you might have a defective thermal head.
Jul 17, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Good luck.
Mac =)
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Communication error # 43on panasonic kx-fhd331
problem with your machines ncu or mb unit.check with proper technician.
Mar 26, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
No phone dial tone
please disconnect power plug from outlet and reconnect it after few seconds(this will make master reset)
Mar 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Fax film pulls through with copies
timing is usually associated with a motor, try and see if the motor can be dismanteld, clean with alcohol and put oil on finger to lube inside.
If not then motor needs to be changed.
Feb 11, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 Plain Paper Thermal Fax Logo
232 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
