While typing on my Toshiba laptop I am somehow accidently moving the cursor back up into the body of the text making what I'm writing appear very confusing. What's happening?
    Problem Solver:
  • 15 Answers
What type of mouse r u using?
Posted on May 01, 2008
On Toshiba Satellite Pro Laptop when I am typing my cursor is jumping to random places in the previously typed text - help!
hi there you probably have the same problem as me with my dell m5040, part of the palm rest shorts with the mouse and becomes active so when your palm or wrist touches it the mouse icon moves and jumps.
martyn
Apr 11, 2013 | Toshiba Satellite Computers & Internet
The cursor jumps backward often while I type, and writes behind where I am, lines behind.
You're probably hitting the touchpad with the heel of your hand while typing. Many people do it without realizing it, and the computer is just moving the cursor to where it thinks you're telling it to go. If you're doing lots of typing, you may want to plug in a USB external mouse and turn off the touchpad. This eliminates the cursor jumping, and a regular mouse makes moving around a document and selecting text easier.
Sep 14, 2011 | Dell Inspiron 6400 Notebook
I have a medion akoya E1222, and when you type the cursor will move to a different part of the text.. muddling up the words...Very annoying
That is because your thumb is touching the cursor pad. It happens to everyone who uses laptops. Some laptop designers put the cursor pad off-centre because of this. With the akoya e1222 you can press [fn]+[f9] and that will disable the cursor pad. That way if you touch the pad by accident you don't mess up your words. When you need to use the mouse again press [fn]+[f9] again to re-enable the cursor pad.
With any laptop it pays to play with those function buttons. There are always some useful ones there.
-Makoto
Jan 14, 2011 | Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
My cursor on my toshiba laptop keeps jumping when am typing
Ive seen this problem a few times, the problem is that your accidently or inadvertently touching the touch pad as you type. To fix this just disable the touchpad when your typing or put a piece of paper over it. To disable the touchpad it varies on different models but can normaly be done with a button near it, a FN and F1-8 key combo or through the touchpad driver on the task bar. Consult your manual for information on how to disable this.
May 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Jumping cursor whilst typing on an acer aspire 5315
Is the touchpad active?
It is common that users accidently touches the touchpad while writing and this causes the cursor to "jump"...
Another possibility is that the "TAB" key is jammed...
May 05, 2009 | Computers & Internet
VAIO laptop cursor moves by itself
Sometimes the surface the mouse is on can make the curs or seem to have mind of its own. Does it behave this way all the time or just here and there.?
Mar 20, 2009 | Sony VAIO VGN-C140G/B Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
While typing an email the cursor will jump back a few sentences
I recently acquired this problem after having my computer serviced. I have been using it for over a year with no difficulty. I read somewhere that this is a microsoft problem, one of their service packages. The question is, which one?
Nov 16, 2008 | Toshiba Tecra M2V-S310 Notebook
Suddenly the cursor moves back to a previous line and continues typing making a joke of what I'pingm typing (see it just did it)
make sure the mouse cursor is further down the page from where you are typing. If your text continues over the arrow of the cursor and any static electricity or touch is detected by the glide pad of a laptop or S.E. from a mouse it will move the text cursor to where the mouse cursor is.
This is a continual problem with sensitive computers.
sorry there is no permanent "FIX"
Jun 04, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
