Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
Install help forWestern Digital My Book 500...
By cjtomahawk on May 01, 2008
I just bought a Western Digital My Book 500MB external hard drive. I followed the instructions to install but my computer won't recognize it. What do I do?
Same Problem
Jan 16, 2009
-   computer not recognizing hard drive-   Guest
Solution #1
posted on May 09, 2008
Not Rated)
PauldLucky
Rank: Guru
Rating: 86%, 243 votes
When connected to a 1394a port on a FireWire dual speed controller (1394a/b) the WD My Book hard drive would not be detected.
Cause:
This is an enumeration issue related to pin assignments of the FireWire controller and the FireWire ports on the hard drive.
Resolution:
Connect the hard drive to a FireWire controller that is either 1394a (FireWire 400) or 1394b (FireWire 800).
If you are using Vista :
You have install the following hotfiexes from the microsoft site
http://support.microsoft.com/kb/940199/
http://support.microsoft.com/kb/937187
You can also try the following steps to resolve this issue:
This is most likely caused by a corrupted INFCACHE.1 file. This file stores the location of drivers and their INF files. This file is hidden, has restricted access, and can be found in “c:\windows\inf”.
Delete the INFCACHE.1 file and it will force Windows to rebuild the INFCACHE.1 file the next time Windows searches for drivers. To delete this file, you have to set the security permissions of it to allow Full Control for the User Group Administrators or full control for your user account. Please follow the directions below:
Open a Windows Explorer window by right clicking on Start and then clicking on Explore.
In the address bar, type C:\windows\inf and press Enter.
Find and then right click on the file named INFCACHE.1.
Select Properties.
Click on the Security tab.
Click on Edit to edit the permissions of the file.
Click on Add to add User Groups.
Type Administrators in the User Groups field and click on OK.
Set Administrators to Full Control and click on OK.
Move or delete the file INFCACHE.1.
Reinstall a device to force Windows to rebuild the INFCACHE.1 file (DO NOT reinstall the same external hard drive that you were having issues detecting before. Please connect another USB device other than the one that Vista had an issue detecting).
This detection issue can happen several times in a row, but repeat the steps 1-11 and try again until this works.
You can download a software to run test on the had drive which can be downloaded from
http://support.wdc.com/download/index.asp?swid=1
You can find the info on the error codes :
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=654&p_created=1035481296&p_sid=yLjari3j&p_accessibility=0&p_redirect=&p_lva=28&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTUsMTUmcF9wcm9kcz0yMjgsMjA5JnBfY2F0cz0xODImcF9wdj0yLjIwOSZwX2N2PTEuMTgyJnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfZm5sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9bm90IGRldGVjdGVk&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
my freecom 1T exrternal hard drive lights up when turned on but does not register with my computer... (More)
Answer
not detecting the external hdd 120gb wd
Answer
My Lacie2Big HArddrive just went dead. the power supply is working, cause i get a 11.9V from a... (More)
Answer
my hp pavilion recognizes my simpletech signature mini (finally) but only as a a 'device'. It keeps... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hard Drives:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14816
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
