Question about Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP not going to POST
Not going to POST, not even reset works. Stopped suddenly while booting. Checked the PSU, Processor, Memory, Video Card with another mother board. All working fine. Replaced 3300uF capacitors that were leaky. Checked the 1500uF and 1000uF capacitors. What else to try? Any help is greatly appreciated, thanks in advance...
  • muljadi May 31, 2008
    Update Mobo driver....
    Novelist:
    Scholar:
  • 148 Answers
You can find leaky caps...
Anyways, those boards have very small inductors that look like caps and are used as pico fuses on most all peripherals and controller chips. Check that they are not blown and replace them with something from DIGIKEY or MOUSER
Also starting with the most simple, check that the power supply itself has not gone into SHOCK. unplug it from mains and TOGGLE the voltage selector switch, MAKE SURE it is back to 110 or whatever you need.
I know it sounds weird but I have resurrected MANY PC's that way.
Other then that it sounds like you are well on your way to finding the defective component on your own. just thought I would throw in the fiew things that have caught me off guard in the past.
Posted on May 01, 2008
Machine was running..stopped suddenly..replaced power supply, cmos battery..nothing..absolutely no response what so ever..mobo is gigabyte 8knxp
You need to disassemble your motherboard specially the processor and the RAM. Once the RAM and the processor was removed you need to clean the motherboard. Re assemble the unit, put thermal paste to the processor so that the heat will absorbed by the heatsink.
Aug 11, 2010 | Gigabyte 8KNXP (MBGA8KNXP) Motherboard
CANT BOOT WITHE HARD DISK SATA ON MATHREBOARD GA-8KNXP / GA-81875
The computer has to be programmed for SATA. Please provide us with the symptoms in detail and we can help you. We will also need the computer Name, the Model Number and verification of the numbers corresponding to your motherboard.
We thank you for considering our service.
My name is Constantin (Arzconst)
May 17, 2009 | Gigabyte GA-8KNXP Ultra Motherboard
Gigabyte motherboard GA-8KNxp will not power up
If you have just installed a new mother board, refer to your manual and double check your connections for pwr switch. If this is a machine you've had for a while and it just stopped powering up then your power supply is probably broken.
Feb 23, 2009 | Gigabyte GA-8KNXP Motherboard
New Build PC not booting
do you get any onscreen information like a bios screen?
Feb 22, 2009 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Motherboard not booting
i think memory probelm
please change memory and try it
Jul 22, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Memory DDR
have you checked the memory settings in the bios check the manual how to do this
Feb 20, 2008 | Gigabyte GA-8KNXP Motherboard
System will not boot
bbios updating required + check ur cmos battery too!
Nov 05, 2007 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-8KNXP wont goto POST
The Power Supply dude/dudette, Ive jst gone through the same thing and found Power supply was fried... Got it working fine now... gotta update Bios tho.
Sep 18, 2007 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP Motherboard Logo
359 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
