Cannot access my internet using my wireless router. Can get on to internet only when plugged directly to modm.
    Problem Solver:
  • 15 Answers
R u using a netgear ?
Posted on May 01, 2008
No internet access netgear router
It may be the device you are trying to connect. shut down everything, unplug , remove batteries, plug in the ISP model, allow the self test, plug in the wireless device, allow it to self test, plug in, reboot the device, laptop, desktop, ipad, phone, whatever. You say you can connect using a Ethernet Cable? Just no connection wirelessly?
Apr 06, 2013 | Computers & Internet
Wi fi is on but still can't connect to the internet
Not only does Wi-Fi have to be on, but it has to be connected to a wireless access point (sometimes called a wireless router), and the wireless access point has to be properly connected to the internet.If the wireless access point/router has empty ports on it, plug your computer into one of those ports, and see if you can connect to ther internet then. If you can, the problem is somewhere between the wireless access point/router and the computer. Could be the transmitter part of the wireless router, could be the wireless network adapter on your computer, or could be the driver that runs the wireless adapter on the computer. If you cannot access the internet when you plug into the wireless ap/router, then you need to go one step "upstream." This would likely be the cable modem or DSL modem. Plug directly into that with your computer, and reboot both the modem and the computer (just unplug the power from the modem and then plug it back in to reboot the modem). If you can connect to the internet then, the problem is the wireless router/ap. If you cannot connect to the internet then, contact your ISP.
Feb 09, 2012 | Gateway 7330GZ Notebook
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Have excellent connection cant get on internet
First thing to try is rebooting devices in this order, 1.Modem, 2.Router and 3.Computer.
If the above did not fix your issue then keep reading.
Plug you computer directly into your router via an ethernet cord and try accessing internet again. If this fixed it, then you have some wireless settings misconfigured. A "hard reset" can possibly fix this by restoring all settings to default. There is a little pin sized hole on the back of your router, inside of it is a button. Stick something like the end of a paper clip into it and press for 5 seconds while the router is plugged in.
If it is still not working then plug your computer directly into your modem via an ethernet cable and reboot the modem then your computer (in that order). Once everything is back up and running, try the internet again. If this fixed it, your router is the culprit and is either misconfigured or malfunctioning. Perform a hard reset as described above to put all settings back to default on your router and try the internet again.
If you still do not have internet access then you either have a computer problem or your internet has a problem or has been shut off.
To rule out the possibility of a computer problem, try your computer at a friends house or work to see if it can access the internet there. If there is an unsecured wireless router that you can pick up from home, try using it just to see if you can get internet access.
If the computer does work when connected to someone elses router, then you need to call your ISP (Internet Service Provider) to see if there is a problem with your account and have them fix it.
Remember that every time you connect a different piece of hardware (router, computer) directly to your modem, you have to reboot your modem so it leases an IP to that specific piece of hardware.
Feb 04, 2010 | Linksys Wireless-G WRT54G Router
I was not able to get on the internet so i had to dc it ad directly conect to the modem is possible the router has gone bad
If you are not network orientated it will be complicated. The simple way to do it is to plug the ethernet cable into the lan port of the router, and it will worked. Your will not have a hardware firewall protection.
Another way is to have the router it's own router and the modm it's own as well. My modem is and my router is those are the lan network address.
Dec 12, 2009 | Belkin Computers & Internet
My router apparently needs to be reset/reconfigured i need help??
You may reset the router set the router back to factory default. Username is blank and password will be admin..
Jul 01, 2009 | Linksys WRT54GC Wireless Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Actiontec Wireless Router not providing internet connection
hi firend
there thats the way but if u have wireless connetion in your router & if u have wireless in your laptop then u can use easy in your home
Apr 27, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
