I need to enlarge an original document on my photosmart C6280 All-in- One. Can this be done without going to the connected computer ?
  • alfordbnf May 03, 2008
    Have now tried and succeeded to make an enlargement as per your instructions. A pity HP did not supply a manual with this machine. Thank's for your help.
  • Anonymous Jun 16, 2008
    I WANT TO ENLARGE A DOCUMENT...I CHOOSE ENLARGE ON THE MENU...BUT WHEN I PRESS START I GET THE EXACT SAME COPY THAT IS ON THE GLASS...NOT ENLARGEMENT..
    Scholar:
  • 60 Answers
Absolutely.
By default, your printer is setup to automatically detect the size of your paper. But you can change that to print up to an 8.5x11 sheet.
So, let's say you have a 4x6 photo you want to make full size, 8.5x11, you must change the settings. Here's how:
You'll want to access the printer's "Print Settings" by scrollong through the menu. Once there you'll scroll up or down to find The Print Layout screen. From there just choose the layout you want and that's it. You'll have to change it back to automatic to set things back to normal.
I work with these printers everyday, but here is a direct link to the manual from HP's website: http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Posted on May 01, 2008
How to scan a document to my computer
if it is XP, then click on start , then run , in run type wiaacmgr.exe and hit enter, try to scan.
In vista and windows 7 , replace run with start search box.
Apr 08, 2010 | HP Photosmart C6280 Printer
How do I scan and save to my computer
Dear Sir,
plz follow this step to solved your problem,
1.
Turn on your all-in-one printer and computer. Check the connections between the two machines.
  • Step 2 Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  • Step 3 Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  • Step 4 Close the printer's document lid slowly so the document does not shift position.
  • Step 5 Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  • Step 6 Push the scan button. You may have to do this on the printer itself or on your computer.
  • Step 7 Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  • Step 8 Edit the image as it appears on your computer if you want to make changes. Your scanning softwaremag-glass_10x10.gif might let you enlarge, resize or otherwise manipulate the final product.
  • Step 9 Accept the scan and save. Return the original document to a safe location.
  • Thanks For Your Time,
    "no scan options"
    " no scan options refer to device documentation for trouble shooting"
    you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
    Mar 27, 2010 | HP Photosmart C6280 Printer
    My HP Photosmart C6280 will not scan documents to my computer. I have it connected to USB port on my wireless PC. I try scanning thru solution center and that does not work. I have turned off the computer,...
    Solution
    For Windows XP
    *Go to Control Panel > Printers > HP Photosmart c6200 series > Right Click > select Delete
    *Load the CD / Downloaded Software for HP c6200 series
    *Select add a device > select usb (if preferred)/ wireless
    *Wait for the installation to finished and repair the settings.
    *Restart PC/ Try Scanning Again.
    If it doesnt work, I suggest try uninstalling and reinstalling the software completely using the CD itself.
    Hope this works. Good LUCK!
    Feb 14, 2010 | HP Photosmart C6280 Printer
    Problems with HP Photosmart C6280 All-in-one Printer
    Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
    NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
    1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
    2. Click Scan Settings .
    3. Click Scan to... Setup .
      NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
    4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
    5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
    6. Click OK .
    Jun 23, 2009 | HP Photosmart C6280 Printer
    I have a HP Photosmart C6280 and I'm packing to move and I don't remember where I packed my manual for the printer. I need to scan a document and I haven't done this before. Can the scanned document be...
    You can download your manual here: http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
    You can scan to your pc if it is connected to your pc and the software/driver has been loaded.
    The pop3/smtp questions are for the address for your mail server (isp).
    It is most likely trying to connect though your pc's mail program (Outlook Express, etc) so if that i snot setup, you would have to set that up first.
    Memory card can be inserted into the printer for saving. You can get access to the memory card in My computer if the printer is connected correctly to your pc.
    Post back with any additional questions.
    Dec 12, 2008 | HP Photosmart C6280 Printer
    HP Photosmart C6280 Scanner
    Hi - You can download the manual by clicking the link underlined in blue below:
    Photosmart C6280
    See page 80:
    You will need the "All in One" software for your computer:
    Software
    Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
    Informatica
    Sep 23, 2008 | HP Photosmart C6280 Printer
    125 people viewed this question
