Question about Acer Aspire 3680 Laptop
Acer laptop 3620 battery will not charge
I have replaced the batter and a c adapter. Battery still will not charge.
I have an Acer Aspire Notebook 3680 and recently started having problems with it not being able to hold a charge. When I plug in the laptop to an outlet it will reads " plugged in, not charging". I was told by a computer expert that it is the motherboard. I've only had the laptop for 1 year, and of course it would have problems one week after the warranty expired.
  • tayabsultan Aug 27, 2008
    my laptop Acer 3620 battry is still but not charging.what can i solve this problems.
  • eddy__15 Nov 17, 2008
    hiiii...
    I have the same prob. with my acer 5310. What could be the prob.???
    HELLLPP!!!!!!!!!
Hiii
I have a Acer 5310 and i have the same prob. dont know what to do is it the motherboard or what??
HELP!!!!!
Posted on Nov 17, 2008
You may want to check the A/C port. Some the ports can come loose from the motherboard due to wear. Can you tell if the computer is getting a charge from the A/C adapter?
Posted on May 01, 2008
    Problem Solver:
  • 44 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
4sd
Posted on Jul 20, 2010
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire one battery won't charge. Please advise my options. Thanks
This problem is usually caused by either a worn out battery (if you've had it for quite a while) or a faulty adapter/power cord. If you know anyone who has a similar Acer Aspire One Netbook, you could try using their battery and/or power cord to narrow down the issue. You can also buy laptop/netbook batteries relatively cheap on eBay and even if the batter ends up not being the issue, you will have a spare battery to take with you or for down the road when your current battery wears out.
Oct 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
Sep 06, 2017 | Acer Aspire 4520-5582 Notebook
I have an Acer Aspire 4520 and the batter will not stay charged and it keeps shutting down even though I have it plugged in. Please help.
Hi there, please perform power drain first. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in, plug in the power adapater then turn on the computer. If same issue will occur then you need to replace your battery.
May 16, 2010 | Computers & Internet
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Battery wont charge
Well the battery is dead. I don't understand your question. You have always been using it on AC adapter, but today you tried using it on battery and the battery was dead? Use the AC adapter and watch the battery and see if it charges. If not take the battery out and then put back in and make sure it is snug so the contacts are touching..if it still does not charge then you need to notify Acer, its under warranty and tell them the battery does not charge and you want a new one..if you have any questions let me know..
pls rate this with 4 diamonds then you can still ask any questions you like.
Mar 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
It's look like your motherboard isnot charging battery.
Feb 01, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 3680 Laptop Logo
255 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
