Question about InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector
Remove the top cover?
I am unable to figure out how to remove the top cover. I removed the front grill, pulled out the lamp, but I can not find any way to pry off the top cover. Any ideas?
  • amp422 May 20, 2008
    Thanks for the help guys. Now I am stuck, I found the fuse and removed it but on the way to buy a new one I lost it somehow. Now I don't know which fuse to buy. I also found out when I asked around that no one in the city sells ceramic fuses.
    Does any one know what fuse I should buy and where to buy a ceramic fuse?
You cannot remove the top without removing the front grill and front cover. Just follow my previous instructions I should know I have dismantled enough of these units.
Posted on May 20, 2008
With the LP500/530 and SP110, turn the projector upside down and remove the 2 torx screws which are on one side. Pull the focus and zoom rings. Remove the front grill which is held by one screw. With the grill removed you should see 2 screws that holds the front cover. Now you should be able to unhinge the top cover, take care to gently remove the ribbon cable that connects the top control panel to the mainboard.
Posted on May 11, 2008
  • 563 Answers
Hi amp422
At the bottom and on the sides of the Projector there should be screws that can be taken out.
Unscrew these and you should be able to open up the unit.
Posted on May 06, 2008
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Tip
Replacing colorwheel on an InFocus X1A, X2, X3, and SP4805
to replace the colorwheel:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. once removed, unplug the flat ribbon cable (for the colorwheel). now facing the front end, remove the lamp and the 4 screws holding the lamp housing (with fans) on to the bottom case. remove the tiny black screw on the small circuit board and remove the board. now you can get to the colorwheel. there are 2 small black screws holding the bracket. pull the ribbon cable through from under the fan. replace with new colorwheel and reverse the instructions. the only difference, remove the front panel from the top by undoing the clips. good luck!
on Dec 02, 2009 | InFocus LP220 Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
How do you remove the "Top Cover" off the InFocus
Michael,en la parte de abajo del lado dellente tiene un tornillo que tienes que quitar y tambien tienes que quitar la tapa de la parte de atras,del mismo lado donde esta el lente tienes que levantar la tapa porque tiene seguros,antes de levantar la tapa desconecta el cable que va hacia los botones de menu,source y reser para que te sea mas facil. espero que esto te ayude . Atte.Rivas.
Mar 16, 2011 | InFocus LP 130 Multimedia Projector
Bulb "End of Life" message
hi,
for replacing the lamp do yhe following.
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
removable
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
Socket
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours ok
Jan 27, 2011 | NEC MT1060 Multimedia Projector
Color wheel replacement
good times here--take the front and rear bezels off and remove the top cover. remove the power input board and power supply. next remove the metal shield covering the bottom of the projector to expose the main board. next, cut the ribbbon cable as close as you can to the color wheel. remove the color wheel leaving the cut ribbon behind. Now, carefully set the new color wheel in the general area and tape the new cable to the cut cable. Next pull the cut cable out of the main board paying careful attention to which way the cable was plugged in. Now pull the new cable thru and remove the tape and the old cable, plug it in, install the new colorwheel and put your projector back together with the exception of the front and rear, turn it on and make sure the color wheel spins, if it kind of just jumps, it means you plugged the cable in backwards. also when you test to see if it works, make sure the lamp door is shut so the safety switch is pushed in, otherwise the projector won't light.
Apr 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use a screwdriver to remove the screw from the cover.
  5. Push up and remove the cover.
  6. Remove the 2 screws from the lamp module.
  7. Pull out the lamp module.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
How to disassemble an InFocus LP640
remove the top case, carefully unplug the ribbon cable from the main board, remove the 5 screws holding the board on, remove the 2 screws from the back (where the audio plugs are), and remove the 6 spacers from the vga/computer connectors. unplug all the plugs (be very careful unplugging the 3 ribbon cables in the middle. unlock the socket first by lifting up on the tab, then pull out the ribbon cables). remove the emi shield from the edge (metal clip with 5 fingers). remove the board!
Oct 30, 2009 | InFocus LP640 Multimedia Projector
Fan does not operate
Make sure that nothing is obstructing the fan. Try to rotate the fan with your fingers to make sure it is free. If it is, you would be lucky if the fan is at fault because this is rather cheap and easy to find if not it is the main board which is at fault.
Dec 31, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector Logo
493 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
