Question about Car Audio & Video
Starting problems MY CADILLAC ELDORADO 1990 MY CR WOULDNT OFF SO I HAD TO PUT A NEW STEERING WHEEL IN AND NOW MY THEIF SYSTEM WONT LET THE CAR START.WHAT I WANT TO KNOW IS CAN I DISCONNECT THE THEIF SYSTEM SO THAT I CAN START MY CAR.
    Genius:
  • 1,689 Answers
I can only speak genericly from what I have seen on some high end vehicles:
The thieft system is working with the complete associated system. Each of the pieces that contain electronics are part of the coded and encryption security. This way parts cannot be easily mixed and matched. Most all of the modules much be programed with the proper codes to match to the system.
I think if you put back the old parts, and if the car was starting before, it should start again if nothing was damaged.
The Cadilac service dealer should have the jiggs and interface to program any of the modules.
Jerry G.
Posted on May 01, 2008
95 eldorado in park key will not turn?
Most of the time this happens when you park on a surface that is not flat and the vehicles weight is putting pressure on the front wheels, which in turn will put pressure on the steering wheel, which in turn puts pressure on the switch and makes it hard to turn. Try to turn the steering wheel as much as you can and turn the key, if this does not work, rock the car back and forth and again try the key until the pressure is relieved and the switch can be turned. Since the steering locks when the key is turned off, you have limited range to relieve the tension. The only other solution to this problem is to jack up the front of the car to relieve the tension on the steering/switch, or you have another issue that would probably require a new switch.
Nov 17, 2013 | 1995 Cadillac Eldorado
My 1994 eldorado wont start the car turns on and the lights go on and it just goes click click. I tried jumping it and it still wouldnt start. Does that mean I need a new starter?
These cars did have problems with the antitheft system. When this system fails, the car "thinks" it is at risk for theft, and disables the starter. I would look into this before you change the starter. This link explains.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 30, 2011 | 1994 Cadillac Eldorado
Need a diagram to put together a 1989 caddilac eldorado power steering,tilt and telescope steering wheel and column.
Excellent tutorial here that helped me when I had a loose steering wheel on my 1988 Deville.
This one is not from an 89 Eldorado, but all GM Tilt/telescoping steering columns from that time are virtually identical:
http://www.diyfiero.com/dropspot/Jazzman_Steering_Rack_Rebuild.pdf
Oct 11, 2011 | 1989 Cadillac Eldorado
My 1990 Cadillac El Dorado wouldn't start. I drove to gas station pumped gas went to leave and wouldn't start. Battery has a charge. When you turn over the ignition you hear the fuel pump kick on but when...
i had the exact same thing happen to me. i still havent gotten it fixed or exactly pin pointed the problem but, when you put the key in an turn it one click until ou hear the fuel pump kick on, then grab the steering wheel at the top and pull it down towards your lap, as your holding it down, turn the ignition over and it should start everytime. did for me.
May 19, 2010 | 1990 Cadillac Eldorado
Keep sayng starting disable dont start
That is the theft system keeping the car from starting. More time than not the key cylinder has broken the wire going to the theft modual. It will require a new cylinder and unless you know what you are doing it is best left to some one who has had the steering colume apart.
Oct 11, 2009 | 1990 Cadillac Eldorado
The engine turns over but won't start on a 1990 cadillac eldorado v-8 it may have run out of gas completely. it started to sputter and bog down and then stopped. i put gas in the tank and it turned over...
You may need to change the fuel filter. If the tank was emptied, the loose sediment on the bottom of the fuel tank probably got stuck in the fuel filter. Change the fuel filter and this ought to solve the problem.
Aug 06, 2009 | 1990 Cadillac Eldorado
There is a roaring sound and hardness in steering sometimes
try turning your steering wheel from side to side all the way to get all the air out of the system,if that dont work,the pump could be going out!
Jul 18, 2009 | 1991 Cadillac Eldorado
1990 cadillac wont start
It's your PATSII security system...Any good mechanic should be able to fix this for $50-100 WITHOUT REPLACING THE BCM (tell them I said so).
Good Luck
Jun 23, 2009 | 1990 Cadillac Eldorado
1991 eldorado wont start
So you put gas down the throttle body and it won't start. Sounds to me like you either have NO SPARK or your plugs are already fuel fouled. Even with you supplying the fuel. it still wont start. FYI, the FUEL FILTER is located by the R/R wheel, and the FUEL PUMP is located IN the fuel tank. Hope this helps
Apr 08, 2009 | 1991 Cadillac Eldorado
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
