Myother computer will not work and it will not let me reboot it what can i do
  • ccanni1028
    ccanni1028 May 11, 2010
    Without more detailed information than "my computer will not let me reboot", help cannot be given. This can be caused by many different problems, each with their own solution.
    Problem Solver:
  • 15 Answers
Do u hear anything when u try to boot (start) it?
Posted on May 01, 2008
Tip
Method to reboot system using CD/DVD or without
There are Various(different) Methods to Reboot Your Computer 1.) Click "Start," then "Turn Off Computer," then "Restart." else 2.) Press "Ctrl," "Alt" and "Delete" simultaneously. Then click "Shut Down" and select "Restart." 3.) Press and hold the power key. Most systems will power down after about five seconds. This will force a hard power down. This method does not give hardware in the system, such as hard drives, a warning that power will be lost, so it is not graceful and should only be done if the above methods did not work. 4.) Unplug your computer and plug it in. And turn on the computer. This will also make force a hard power down, "Make sure that if the other command/option did not work (function)" so you should only do it if other methods did not work.
Reboot Using a CD or DVD 1.) Place "insert" the CD or DVD into the disc drive of your system (e.g E:,F: or G:) that you have. 2.) Restart your computer using any of the methods listed under "Various Methods to Reboot Your Computer." 3.) When prompted, press any key to boot the computer using the CD. 4.) Contact your computer's manufacturer if this does not work, and make sure that the CD or DVD is good. If not it will not work "Cannot run for booting" or computer may not be set up correctly, and various troubleshooting methods are required to figure out what is not working.
Else if you want to Reboot Your Computer into Safe Mode Here are the step to run in a "safe mode" 1.) Turn off your computer and Wait for few seconds. 2.) Restart your computer. 3.) Start tapping the "F8" key for a while and wait till the "windows advanced option" menu appear. 4.) When the "Windows Advanced Options Menu" appears, select "Safe Mode" using the arrow keys on your computer and press "Enter" key in your keyboard.
All the Best!
on Sep 13, 2010 | Computers & Internet
Tip
Sansa View: is not recognized by my computer
See myother TIP posted here on this site. About MSC and MTP Connection problems.
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
First thing to do is:
Try otherUSB ports on your computer. A USB port on the back of a PC usually has better poweroutput.
Try adifferent cable if there's one available, to rule out if you have a bad cable.
Tryanother computer.
If none of the above works:
Then-Check and refresh the drivers in Windows, for a Portable Device.
1 -Connect your player to the PC
2 -Check under Device Manager
-> 1.Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2.Portable Device (if the player is set to MTP mode.)
(See my other TIP listed above for an Explanation of MSC and MTP modes)
If thereis a yellow exclamation point (!) or question mark (?) beside the device, tryto refresh the drivers.
Then -Refresh the drivers
1.Right-click the entry with the error mark, select Uninstall.
2. On thetop menu, click Action then select Scan for hardware changes.
If your BRAND NEW player is NOT recognized by the computer when plugged in:
This may becaused by one of the following:
1.Minimum system requirements were not met.
2.Corrupted drivers.
3.Computer restrictions, Vista or 7 authorizations.
4. Powerissue, plug your player into the back of the computer.
Next be sure you are using WindowsMedia player :
Version10 or 11
Downloadand install the latest Windows Media Player if it's not installed.
If all this has failed - Refresh the drivers again.
If allthat does not work - Manually add the hardware driver.
1. Connect the Sansa player in MTP mode
2. Manually install the device driver through Windows device manager in control panel. Install the Device as a Portable Device.
on Jan 11, 2010 | Audio Players & Recorders
V3-531 reboot without disk
You don't need disks to reboot. Just click "Turn off computer" under the start menu, and then click "Reboot". If that doesn't work, hold down the power button. After ten seconds or so, your computer will shut off, and you can restart it again simply by pressing the power button again.
Jan 31, 2013 | Computers & Internet
I have a Lexor 8GB Jumpdrive TwistTurn that mt compiuter will not acknowledge. When I plug it in my computer makes a different sound from the normal sound it makes when it acknowledges or accepts a flash...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Apr 04, 2011 | Computers & Internet
My labtop mouse just stopped working. I rebooted
Unplug it, count to 10, plug it back in, count to 10 and it should work.
If not, try it in another computer.
If it doesn't work on either computer it is defective.
Nov 30, 2009 | Acer Computers & Internet
Computer keeps rebooting
just check if you get a blue screen with lots of text messages just before your PC reboots. also if you have any hardware knowledge or if not ... get your vendor to check the RAM and also check if your CPU fan is working properly.... let me know...
Dec 03, 2008 | Microsoft Windows XP Home Edition
My computer keeps rebooting after if reaches windows xp logo
I also have this same problem about a constant reboot of computer and what I did is I replace the Power Supply and everything is already working , becauise this problem can be link in failing power supply already...
Hope that helps..............
Oct 05, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
My Keyboard only works on one PC but the monitor and mouse works on both?
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Oct 09, 2007 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
