HP Compaq Evo N1000v Notebook Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. l am trying to boot a compaq n1000v.. from the usb but l cant see where l can change the booting in the bios.. please
Anonymous
Level 2:
Sergeant:
  • Expert 238 Answers
  • Posted on Aug 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
238
Questions
0
Helped
43286
Points
570
Switch on the PC & press & hold F12, F9 & F2 to enter bios setup.
if not working press dell button & hold (common for most of the laptop)
1helpful
Hi, I can't boot from USB on compaq Evo n1020v please help. Thanks
a 2002 PC made new, 20 years old, a record here for old and
useless really it will grow a virus soon, (I warned you)
last person on XP on earth are you, ?? why?
most 2002 PC can not boot all things we see now today.
usb what, not told.
I have USB SSD, drive
USB flash memory thumb drive.
USB m2. drive
USB DVD drive.
2002, boot choices, in the manual.
hdd
cd
floppy
no usb listed in the manual
go bios PAGE 1 setup
find all entry points showing USB
the all for boot
see no USB devices allowed boot in 2002
see boot order, in bios if the device fails to show up there it is dead.
what did you put on the USB drive, Linux installer?
not told.
the manual tells to set boot order first, to 1st thing needed to boot, if USB fails to show up there , it does not support it.
some relic BIOS ive seen have line there called allow USB to boot. no kidding look for that too.
answering for usb boot device not told tested and working on modern PC.
I have hp compaq 6730s before its got xp windows now the windows is corrupted now when I instal xp windows the system doesn't boot with external cd/dvd rom since the its own dvd rom doesn't work properly...
2008 PC from HP(old compaq name)
RECOVERY this PC ,per the book. (Ive done it)
this PC has a working F11 key if the HDD not bad, not changed out or the F11 partitions not damaged,
Power on hit F11 per the service manual. page 141
http://h10032.www1.hp.com/ctg/Manual/c01613452
CD boot fails
to boot to CD you must hit a key, called hit any key
to boot CD (aka. offically El Torito spec, wiki that and learn this)
If you dont hit (I use the huge space bar so easy to reach)
then no CD boots ever. by DESIGN. on new PCs that is true
and now you have to turn off SAFE BOOT too.
so those rules are first.
some PC, even make me hit (HP) the space bar to boot USB sticks this too is a fact. so do that.
my guess F11 is dead so you used discs, unstated disks , no HP disks (RIGHT>?)
XP the dead OS, this means adding things, , to the PC.
will fail. XP plug and play is dead, for vast things now for 3 long years, since MS ended this support. why not upgrade XP
to W7?
Old PCs do not like to boot , to external drives, its modern IDEA that (2008 is not too old,but IDK , if yours has it)
If you did boot to CD , inside or outside
XP (from MS ,not HP) will ask you to find drivers, and tell you to hit F6 and insert a floppy, tell me how you can get past here?
you cant, using NON HP install medial
XP is 2001 disks, 16 years old laying about. from MS
and guess what it cant see your HDD. due to no SATA drivers.
so the path you are on is full of pitfalls. see?
a modern feature in BIOS,its 100% a features of BIOS to boot any USB or External drive, (but eSATA might boot , not you no esata)
you posted with no mention of what external drive you have.
USB , esata, or what? Im guessing USB cable external drives.
the External drive needs a power pack to run right i most cases.
in bios, go to ALL screens, power on hammer F10
Setup bios is F10, go to all screens and turn on all USB features.
then change boot order to.
CD (hit space bar to boot CDs or DVD)
USB (hit space bar to boot USB devices (any key = space bar)
HDD.
then if all that above shows up F9 can be used to override above.
F9 only works if and only if.
1: bios supports it,! (IDK)
2: bios, has all USB features turned on, in other pages in BIOS.
including USB boot , turned on, if seen there. it must be on.
Enabled!
3: F9 only changes boot order this time, it does not enable features, that do not exist. ever.
why in the world not get a good CD/DRIVE. its like $10 used on ebay, pocket change, no?
or install with USB sticks?
there is legacy USB setting in BIOS, turn that on.
I can not teach you BIOS. (ive seen them all, so know this.)
but not yours, HP chances them like the weather, like the changing of the wind, directions. makers of BIOS changed 4 times!
and upgrades on BIOS changed on some HP PC, 10 times. or more. so I know NOTHING here, nor will most others due to that FACT. (unless theirs, is same as yours exactly)
only you can can explore BIOS, page by page and see what is there.
Test 1. (all techs have this in there KIT)
boot from USB stick, NOT external DVD drive)
if this fails doing DVD external boots is not possible.
find say any ISO for Unbuntu 17 linux, and burn the USB stick
using rufus. the boot the stick (fail now)?????????
that is the test for USB boot if that fails the PC is too old
and only fixing your bad DVD drive is the only cure.
Do not run XP with out SP3, once you have it running
XP has 700 exploits, and is a virus magnet.
never use XP is the best answer, but you you are not there yet.
so only BIOS matters now, that and only that NOW>
if the USB test 1 above works, I would.
id buy W7 from microsoft.com
the burn a stick
then load w7 , now it has future.
this PC is supported by HP in W7
here is the proof here
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-6730s-notebook-pc/3687778
never run XP or VISTA today, 2017, they are now officially dead.
Learn that booting is a function of BIOS not windows.
windows is a goal and is only startup files to load windows.
booting happens at the lowest levels ,in BIOS.
BIOS has code in my newer PC to boot to any USB device.
but not external drives.
tricks for compaq old
6730b the CD is called,
'Notebook Upgrade Bay'
(odd name that)
but I have a SDD in mine so not so odd !
trick 2, is some compaq change sata to IDE or the CD will not boot. (sad no?)_
BTW my HP laptop can boot to both bays, HDD and upgrade bay
both bays in mine are SDD. one is w10 other is Ununtu 17.
booting to external drives are the most difficult tasks of all
some do , some dont.
but I always start with a stick first. test that , for booting
then go wild with external drives. (booting )
this is all for now, we can peel the onion as deep as you want, ask.
1helpful
How to boot from flash disk compaq evo n1000v
If the BIOS configuration for the boot order does not have an USB device in the list then this model laptop cannot boot up from an USB flash memort stick.
2answers
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
[email protected]
www.sureshayyar.110mb.com
HP D530 SFF cant boot from sata drive . please help.
Is that a USB drive? If it is set the BIOS to boot from USB or it won't boot.
We understand that your problem is: Hi please help me i dont know what to do i purchased a used compac tc1000 tablet pc on ebay for college and It had ubuntu installed on it and not windows xp it did come...
Hi First you need to make the USB CD-rom Drive as the first boot device by going to BIOS setup by tapping F2 when the system turns ON , after changing the boot order insert the first disc and restart the computer it should run from the disc.
How to boot from flash disk on compaq evo n1000v
The option should be available via the boot menu in the BIOS
2helpful
3answers
Can i boot from usb
I'm sorry but the answer is no.
You only have floppy, hard drive and cd-rom options. With some Dell models the USB is seen as a secondary hard drive from within the BIOS so maybe (if your bios supports it) you can change boot order there.
Usually thats not the case so you mainly have to boot from the CD/DVD to install or run a DOS or linux command.
Regards.
4helpful
4answers
How can i boot up from usb when my bios doesnt have usb option in boot menu
You may not see option for USB drive unless you have a USB drive connected when you go into the BIOS.
Otherwise, you will need to attach a floppy drive, and create a boot floppy that then loads drivers and such for the hardware, as well as the interface, and eventually, the drive itself.
Compaq evo-d510-boot problem
change the boot sequence in the bios setup into
HDD
CD drive
Usb
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
