Question about Whirlpool WFW9400S
Whirlpool Duet Error code F 32
I turn on my whirlpool front loading washer it acts like it is going to start then the door locks and I get this error code. ???? Help please
Whirlpool Duet WFW9200SQ02
Same problem here. Started a load, started filling about 10 seconds, locked-unlocked-locked again, and then F32 code.
Canceled the cycle, and took about 10 minutes to drain what little water there was in it. Turned off the water at the connections, worked just fine on Sunday. Wednesday--nothing.
Unit is about 3 months old.
  • 12 more comments
  • Anonymous May 11, 2008
    I have the same problem can you tell me anything else I can do.
    yes I do
    yes I do please help me
  • Stogiez May 12, 2008
    Dutchman05,
    Thanks for the info. I have called for a warranty service call since the unit is only three months old. I don't think I should have to pay for a part on a brand new machine.
    But it is very helpful to know exactly what the cause of the problem is so when the tech comes by, he does not "try to blow smoke," and weasel out of fixing the machine.
    I say "weasel out" not because I don't trust technicians, but my experience with Whirlpool service on this washer has already been disappointing.
    The service company that Whirlpool uses in the Allen, TX area assigned a tech to come to my house on Friday May 2, 2008 between 1-5 pm. I called at 5 pm to find out where the tech was--he was still at the service appointment prior to mine. At 6 pm, I called again, same story--he is still on the service call prior to mine. At 7:30 pm, I called and the dispatch center stated the tech "called the customer and no answer. Service call cancelled." Coincidence that the tech called the last two appointments on a Friday evening, and BOTH were no shows. A&E is the service company Whirlpool is using for the Dallas area.
    Dutchman,
    Wanted to up the rating from Very helpful to FixYa, but it is locked.
    The tech came by this morning and repaired the unit. It was indeed the pressure switch. A couple of comments and suggestions were made by the tech and all made sense to me.
    First thing he did was look for baby socks and other small articles of clothing at the pump. That would probably cause an F32 error since the unit was not be receiving the correct pressure. Nothing clogging the pump.
    Then he replaced the pressure switch. He stated that there is a "break in period of about 3 months and that a pressure switch can get kinda delicate." He also noticed that I have the Watts Floodsafe water hoses, and said that if the F32 code appears again within a couple of months, I should try changing the water hoses to a set that does not have the water flow restrictor, or at least try "resetting" the water shut off on the hose.
    The tech was professional and appeared to be very knowledgeable.
    Dutchman,
  • Anonymous Jun 08, 2008
    f 32 code
  • Anonymous Jul 10, 2008
    Same problem only we just had machine delivered today. Nice!
  • ramit345 Aug 03, 2008
    We turn on our washer and it starts to fill for 5 seconds, locks and unlocks twice, then just flashes f-32.... Very frustrating since the unit is 3 months old as well!!!!
  • Anonymous Sep 13, 2008
    This same thing happened to my washer as described in the previous postings.  The pressure switch was the problem.  The technician, in my case, checked the the guide that is located on the lower right side under the tub. The the guide lists the error codes and the the fix. My technician when directly to the guide.
  • Anonymous Feb 09, 2009
    We had this same problem. We sucked up a carpenter pencil. My husband, who is also an auto mechanic, took the pump housing apart and retrived the pencil. We had to use a wet and dry vac to pump out the water. Got the pencil out, put back together and all is well.
    The Greens in Alaska
  • Anonymous Mar 21, 2014
    unit will start to fill and then stop pause start to fill again then stop with error code f11
  • Anonymous Mar 22, 2014
    I have Whirlpool duet sport washer and it seems like it is going to start but then the cycle doesn't. It clicks a few times and stays locked for a bit but then it just shuts off. I can cancel the load and open door yet....what would the problem be?
    what is the capacity of it
    President:
  • 1,294 Answers
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
Folks,
After spending half a day trying to nail down the root of the F32 error code on my Whirlpool, I surrendered and went to the parts store. I picked up a new "pressure switch" and also a "drain pump" as I was getting the F21 error code as well. It should be noted that I tested the pressure switch line (all clear) and also pushed a little air through the pressure switch itself and it made the clicking noise it is supposed to make. For those reasons, I was skeptical that the problem was the switch but when i installed the new one and ran through the diagnostic routine....shazaaaam....no more error codes!
So even if you think the pressure switch sounds fine, when faced with a F32 error code, go buy a new switch and get washing.
It should be noted that the service depot knew all about this problem and indicated that Whirlpool knows about it too....
Rob
Posted on Jul 25, 2008
  • 487 Answers
Whirlpool is very secretive about this and you find every code in the book except this one.
What the problem can be:
Unplug for an hour and plug it in again and try.
Normally this clears the error.
The water inlet can be obstructed. That means the filter in or at the end of the hose. Normally it is a filter in the inlet port of the machine
or....... the filter for the drain is plugged /or drainpump obstructed.
Clean this all and it should be over.
In the mean time I am in contact with Whirlpool but it is a pain in the @#@@
Posted on May 01, 2008
  • eric bosman
    eric bosman May 02, 2008
    OK just came back from whirlpool.
    F32 means pressure switch failure.
    Either the hose leading to the pressure switch is blocked or leaking or the pressure switch is broken
    You need either to call for service due to warranty or... order part here It is number 20.
    This will also indicate how to fix it
F32 code on the whirlpool Duet 9400 ended up being a clog in the pump. I found one of my kids socks. I have no idea how is got past the tub. I hope this helps someone with similar issues.
Martin
Posted on Nov 25, 2009
I have the same problem with this washer. I just got it delivered today. I can't believe it so many people having this issue. This is a bad model?
Karen
Posted on Aug 01, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet - door will not lock. Was working fine and now when I press start, I get the code "FL"and then "d" flashing.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Jan 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool door lock error
turn off all water to your washer run the washer empty for a full cycle when the cycle ends the door will release
spray a lubricant such a WD40 into/onto the door lock
the door kit will not fix the problem
Jun 01, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
My front loader washer whirlpool codes fdu and the door won't unlock.
F/dU error means --------- Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9400S Logo
7,153 people viewed this question
Dan Webster
Dan Webster
Sal De
