WATER WILL NOT SHUT OFF
TRIED FROM EMPTY.  STILL  HAPPENS MUST BE SENSOR.  NEED HELP
  • 3,037 Answers
GE Parts Department 1-877-959-8688 Hours Monday - Friday 7:00am - 6:00pm CST, and Saturdays 7:00am - 4:00pm CST.
Call the above number, tell them your problem and your model number and they can get your part for you.
I believe that this is the part you need, but confirm with them first, and let me know how it goes
SWITCH PRESSURE 10 WH12X10065 $38.75
Posted on May 01, 2008
My Maytag Bravos x will not move past the "sensor" mode. How do you reset it? It has power and water. It worked fine one day and the next, just doesn't move past sensor phase into wash. Or anything.
I think you will find that the water pump is not emptying the machine first as it needs to, only when the water sensor knows there is no water in the machine alternatively check that the water valve is operating as it should fill strait away on switch on, mabe the water valve is not working as this happens quite often, replace water valve and try again n eric
Jan 12, 2018 | Maytag Washing Machines
I have a model 6805 and in the middle of rescaling, it keeps displaying to “empty drip tray!” I cleaned sensors, restarted program, turned on/off. Still reads “empty drip tray,” This has happened before...
Try using CLR (calcium, line, rust [remover]) or an equivalent product, that is soaked into a Q-tip to clean the sensor. You may need to repeat the process a few times, using a Q-tip with water between to take off layers. Another tip that you may want to do is using a cleaning solution in water to run through the system once or twice followed by brewing with WATER ONLY to rinse it. Hopefully that will solve the issue and leave your unit healthy for a lot more time.
Dec 24, 2017 | Miele Coffee Makers & Espresso Machines
Fridgedair Stackable washer /dryer...fill water cycle does not shut off.
The fill level sensor has probably failed. If you open it up, you should be able to find the sensor. There will be two of these (full and empty)- they are usually disk like object ~ 2 inches in diameter, with a rubber tube coming from the centre. I would try swopping them over. If the fault moves from 'not stopping filling' to 'not trying to empty' (or similar change) you have found the fault. Buy a replacement from an on-line spares supplier.
Apr 07, 2016 | Washing Machines
Overflow tube
If you manually pull up on the float of the fill valve will it then shut off? If it does, most likely your water pressure is too high, should be around 60 psi. More then 80 and it won't shut off. You may need to add a restrictor to the fill valve. Most fluid-master units come with one already installed, you could try one of them.
Feb 05, 2014 | American Standard Home
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
The water empty indicator keeps flashing indicating we need to empty it BUT it is empty !!!!Now the aircon won't work We emptied a lot of water however now it keeps beeping a warning,the compressor shuts...
I am NOT aquainted with the Maytag Portable AC..... But There has to been a sensor that tells the unit that the water bin is full...... If there is any moisture on the sensor and touching a ground probe then even though the bin is empty the sensor is still making a connection to ground. If you can trace out the wire that goes to the sensor you can unplug it from the board till it dries out or you replace it..... Only if you do make sure you empty the bin often or you will have water every where because the unit won't shut off if the water bin is full..... Hope this helps
Feb 05, 2011 | Maytag Portable Air Conditioner M6P09S2A
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Dishlex Global 450 flashes ''oF'' - Continues to drain
I also had the oF error message just today, tilted the dishwasher back 45degrees and message dissappeared and all sweet as now. Put old towel under legs to catch overflow Thanks to david
Dec 29, 2008 | Dishwashers
Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Aug 02, 2007 | Maytag NMPEB08F2A Air Conditioner
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
