Question about Vivitar ViviCam 5100 Digital Camera
GETTING VIVITAR5100 TO PRODUCE PICTURE IMAGES ON COMPUTER
CANNOT CLICK ON TO REMOVABLE DOES NOT APPEAR ON SCREEN WHEN CONNECTED TO CAMERA;AND COMPUTER HOW DO I GET REMOVABLE DISK TO APPEAR WHEN I CONNECT TO COMPUTER??
  • 797 Answers
You can try to re-install your software and drivers.
Also, get a card reader. Download your files from a card reader and not necessary to use the usb cable connected to the computer.
Posted on Sep 06, 2008
How do I transfer images from a sony a200 to a mac I keep getting cannot trasfer tempory images
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Apr 09, 2013 | Sony Alpha DSLR-A200 Digital Camera
Kodak z740 will not download pictures from camera to computer
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 25, 2012 | Kodak EasyShare Z740 Digital Camera
I Can't see the pictures or even copy it when I connect it to the computer? what will I do? thanks. GODBLESSU!!!!!!!!
The solution depends upon the Operating System. There are many options for transferring the images from the Camera to the Computer. You can either use the supplied Software for transferring the images to the Computer or with the help of Windows Explorer.
Let's try to set the Camera in PTP/MTP Mode and check if it the computer detects the Camera as a Removable Drive. To set the PTP/MTP Mode, select the USB Connect option from the Main Settings 2 Menu of the Camera.
If the Camera is detected as a Removable Drive in the Computer window, then open the DCIM Folder to copy all the images.
If the Software is installed in the Computer, then the Import Media Files screen of the Picture Motion Browser appears automatically.
Click on Import option to import the images. By default, images are imported into a folder created in Pictures folder that is named with the date of importing.
This should help you in transferring the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I get "communication error" on the screen when in
PicturePerfect was retired years ago, replaced by Nikon Transfer and Nikon ViewNX. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/13948
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 07, 2010 | Nikon Coolpix L11 Digital Camera
How to tranfer images from camera to laptop
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Sep 24, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
How do i view stored pictures
Thanks for contacting FixYa for your problem.
In order to view pictures stored in your Camera. Please do the following:
  1. Plug the one side (usually small) USB cable into your Camera and other side into your Computer USB Port.
  2. Once connected, you need to ON your camera.
  3. Once ON your computer will detect it and may be you will get option on your Camera about the mode to chose, so chose Disk Storage.
  4. Once you select the mode your computer will automatically detect and will install the required Drivers for it.
After Drivers Are Installed:
After drivers are installed, do the following:
  1. Go to My Computer.
  2. Locate for any new drive (usually Memory drive, or may be a new drive will appear other than your normal drive partitions i.e. C, D, E...). This will contain all the date in your camera.
  3. Simply double click that drive and look for the folders for your pictures.
  4. You can simply copy and paste them to your computer or cut them or delete them without any problem as per your needs.
I hope this will help you all, if not, then do let me know I will assist you in this regard further.
Kind Regards,
Khawar Khalid
Jan 30, 2010 | Vivitar ViviCam 8025 Digital Camera
Lost cd rom
You can use the Camera without the installing the software supplied on the software installation disc.
The simplest way to transfer the photos from the Camera to the Computer is to connect it to the USB port of a Computer then follow the following steps:
1. For Windows Computer:
(a) as soon as the Camera is connected the computer recognizes it as a removable drive.
(b) open the windows exlorer by pressing the "Windows + E" key together.
(c) locate the removable drive in the windows explorer that represents the connected camera.
(d) double click the drive to navigate through the files and folders, then double click on the DCIM folder to view all the images.or navigate through other available folders to check if the images are stored in them too.
(e) select all the desired images then copy them by pressing "CTRL+C" then paste them on the hard drive of the Computer by pressing "CTRL+V".
2. For Mac"
(a) as soon as the Camera is connected the computer recognizes it as a "NO NAME" folder and display it on the Desktop.
(b) double click the "NO Name" folder to navigate through the files and folders, then double click on the DCIM folder to view all the images. or navigate through other available folders to check if the images are stored in them too.
(c) select all the desired images then copy them then paste them on the hard drive of the Computer by using the copy and paste operation.
Furthermore, you may use Windows Fax Viewer, Windows Photo Gallery or Windows Movie Maker to view and edit images in Windows and iPhoto in Mac.
Oct 10, 2009 | Oregon Scientific DS6618 Digital Camera
I have a Sony Cyper-shot 6.o Mega Pixels camera (given to me with no manual) I've got the cord to connect camera to PC. I cannot figure out how to load the pictures from the camera onto my e-mail account.
The mamory card in the camera will show up as a "Removable Disk" on your computer.
1. Go to "My Computer". The camera will probably be Drive E.
2. Click on Drive E (or whatever the "removable disk" is) and open (click) any folders that show up. The pictures will be several folders down.
3. You can then copy these to your "My Pictures" folder in "My Documents" or "browse" to that drive when you want to attach a picture to your email
Hope this helps!
Sep 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Can't download my video files from xacti e2 to my computer
TRANSFERRING RECORDED IMAGES AND VIDEOS FROM YOUR VPCT700 DIGITAL CAMERA TO YOUR COMPUTER
Connecting the Camera to Your Computer
1. Connect one end of the USB cable to the PC/AV terminal of the camera.
2. Connect the other end of the USB cable to an available USB port on your computer.
3. Turn on your camera.
-The [USB] screen appears.
4. Select [PC] with the Up and Down Arrow buttons, and press the SET button.
5. From the Windows desktop, double click on “My Computer”.
6. Look for a new “Removable disk” icon. This “Removable disk” is actually the memory card in your camera. Typically, the camera will be assigned drive letter “E” or higher.
7. Double click on the removable disk and locate the DCIM folder.
8. Double click on the DCIM folder to open it to find more folders.
-Your recorded images and video clips will be inside these folders.
-Copy & Paste or Drag-N-Drop image and video files to a folder on your computer.
Mac users: Double-click the “untitled” or “unlabeled” disk drive icon on our desktop. iPhoto may automatically launch.
Downloading images and Video Files
When the camera is turned on and connected to your computer, it is considered to be a disk drive, just like a floppy disk or CD. You can download (transfer) images by copying them from the “Removable disk” (“untitled” or “unlabeled” disk on a Macintosh) to your computer hard drive.
Windows
Open the “removable disk” and subsequent folders by double clicking on them. Your images are inside these folder(s). Select the images that you want, and then choose “Copy” from the “Edit” menu. Open the destination location (folder) and choose “Paste” from the “Edit” menu. You may also drag and drop image files from the camera to a desired location.
Macintosh
Open the “untitled” disk icon, and the destination location on your hard disk. Drag and drop from the camera to the desired destination.
NOTE
- Memory card users may prefer to use a memory card reader (highly Recommended).
- Video playback application is not included with the package. Make sure that video playback application has been installed in your computer.
Feb 13, 2009 | Sanyo E1 Flash Media Camcorder
PC Connection
i think it is bad connection from the usb cable to the camera try to move the connector in the camera( bending)
Jan 07, 2008 | Pentax Optio M20 Digital Camera
Vivitar ViviCam 5100 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
