Question about Car Audio & Video
Heating systom my heating systom in my van has just packed up and i cant solve the problem as i cant see any fuses blown
    Genius:
  • 1,224 Answers
Your heater should be running off the heater core which is front passenger side if your floor is soaked then heater core is out and in vans it cost arm and leg to replace need a little more input i had the same problem with my van heater went out found out it was a bad heater core leaking 2 ways of fixing this
cheap way find the 2 heater hoses to fire wall disconect off fire wall and connect together
expensive way replace heater core its a lot of work in a van
Posted on May 03, 2008
  • Christophe Thompson
    Christophe Thompson May 03, 2008
    P.S. the heater core isnt more or less to say electrical as more as it mecanical its a hot small radiator on the passenger side front of vehicle controls might be electrical and the problem could lay within the controls on the dash
How can you fix internal soleniod in a transmission?
go after the P1768 code first. sounds like trans relay is not sending power to the solenoid pack. check fuse #2 {should be a yellow 20 amp fuse} in underhood fuse/relay box. if it's blown it will cause all these codes. the relay is marked EATX and is in the same box as fuse. should be in one of the corners of the box. hope this helps, let me know
May 28, 2014 | 2000 Dodge Grand Caravan
94 chev lumina van fuel pump fuse blows
check wiring to the fuel pump connector(from kick panel back),and inside the connector for melted plastic/shorted terminals.too much load from a bad fuel pump can heat the small connectors up alot.
Dec 24, 2013 | Car Audio & Video
No temperature display cant set temperature
Located behind the access panel there is a grey box that is the spa pack. Open that up with the 2 screws on the top of the pack. There is a small glass fuse on the circuit board. One of those fuses is most likely blown. If that is not the culprit you need a new topside control. More than likely it's the fuse.
Mar 04, 2013 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a 2006 Dodge Caravan and the heat, radio and wipers quit working, as well as power windows? Replaced battery and replaced a big bwd fuse, alternator? What may be causing this and is it common in...
Their is a problem somewhere and answer is the blown fuse in the power distribution box under the bonnet ,so no doubt its blown the fuse again and the answer is to find out why ,if it hasnt blown the fuse again then their is a break in the power cable to where it goes to next which is the internal fuse box so check the cable froim the big fuse to the internal fuse board for damage .
Feb 22, 2013 | Cars & Trucks
2009 cargo van chevy 2500-- cant find fuse for left directionals
first never plug back in to that trailer, it may have bad wiring, the next thing to do is to check the front and rear bulbs, they may have blown,if it was a fuse the signal inside would not blink,so this tells me you may have blown the bulbs,and also this trailer is unhooked from the van and lights still dont work?. good luck.
Mar 21, 2010 | 2009 Chevrolet Traverse
I have no heat in the van-no blower or heat. Is
there are several probable cause it may be a fuse blown, resistor block which you can check for continuity or a blower motor prob.These things need to be checked one at time
Jan 30, 2010 | 1996 Ford Econoline
My van overheats and when it starts overheating it starts to lose its heat
Blown head gasket sounds like mate. or else could be blocked radiator and the water is not circulating to cool the engine or give out heat have it flushed by a garage might solve your problem if it doesnt more then likely head gasket.
Jan 27, 2010 | 2003 Kia Sedona
Cant get dryer4 to heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 30, 2008 | Frigidaire GLER642A Electric Dryer
No heat, rough idle then pop and smoke from coil pack 2001 caravan 3.3
YOu should be able to tell if coolant leaks caused the coil pack to fail. I believe it is 2 issues.
Oct 29, 2017 | 2002 Dodge Caravan
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
