Question about Kenmore 62602 Electric Dryer
Kenmore 600 series electric dryer
My dryer just began taking an exceptional amount of time to dry a load. We have blown out the hose at the back of the dryer and cleaned lint trap regularly but the hose that connects to the wall seems to be filling up with condensation so obviously we have ablockage somewhere! Please tell me where to begin :)
  • 3 more comments
  • Anonymous Aug 05, 2008
    dryer is not heating up
  • Anonymous Sep 05, 2008
    dryer does not dry
  • berwill12 Sep 08, 2008
    my dryer also take a long time to dry the clothes i clean the filter very time I put something in it ....it just takes forever
  • Anonymous Dec 07, 2008
    Worked fine for a couple of weeks, then stopped heating. Repair man couldn't help. Then, all of a sudden, it started working fine again. Recently stopped heating again! What's going on?
  • Anonymous Feb 07, 2009
    I have the same problem with mine - no lint blockage anywhere, but exceptionally long drying times. I'm looking into taking off and inspecting the blower wheel. Btw - thanks to the ********* who said "get a new dryer" - go **** yourself.
Get new dryer!
Posted on Oct 11, 2008
    Genius:
  • 1,028 Answers
Start outside at exhaust hoot look for blockage there first look for steep dip or drop in line where condensation can acumilate
Posted on May 02, 2008
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Frigidaire Front Load Dryer Model # leq2152eeo Problem: it is not drying the clothes. The dryer heats up and everything else is working, except it takes 4 cycles to dry something that should have dried...
while the dryer is running.go to the outside of the house and check the air flow,there should be a large amount air being blown out if there is not check the vent and ducting for lint build up and make sure the hose is not kinked.
when there is restricted air flow all the warm moist air will stay in side the dryer causing the clothes to take a long time to dry. i hope this helps you with your dryer
Jan 24, 2010 | Dryers
Slow drying time
very simple, do this test, take your vent hose off the back of your dryer, now dry a load of clothes, if it still takes a long time to dry, then you may need to replace your thermastats, if it works better, your vent hose was pushed in, or smashed or the vent from the wall to the outside is clogged.
thanks Whites appliance repair
Sep 07, 2009 | Kenmore 659 Electric Dryer
Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Aug 10, 2009 | Kenmore 600 7965 Dryer
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
My dryer is really hot when it is running, but is taking a really long time to dry the clothes
Make sure you check your exhaust hose. It shuld be clear of any lint , and properly exhausted to outside of the home . Try turning on the druer with no load and no heat , find your outside vent and check for air flow . If none is felt you suhld move your dryer away from wall ( if aplicable ) and disconnect the hose and check for any blockage , You can even try the above step with the vent hose disconnected to make sure that the dryer it self is properly venting ( feel for ALOT of air coming out of exhaust port ) . If only a miniscule amount of air ( or none at all ) is coming out of the back of the unit you may have to call a technician to come in and clear out the internal duct work .
Jun 09, 2009 | Kenmore 600 6962 Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
421 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
