Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Samsung HL-R4266W 42 in won't turn on
This is weird and hard to explain... Every 4 or 5 days, when we try to turn the TV on the red stand by light goes off, the green lamp light on the right blinks on and off once, we hear the clicking sound the TV usually makes, the stand by light blinks on and off once, then the green lamp light blinks on and off for awhile. Then all lights turn off and the screen pulses with a very dim light. Eventually the stand by light comes on again and the screen stops pulsing. When it is going through this cycle, pushing the power button doesn't do anything. The next day or even sometimes later in the same day it will work fine. We thought it might be the lamp, but the fact that it works fine for a few days leads us to believe it isn't. Any ideas??? Thank you!
  • 1 more comment
  • kruserz May 02, 2008
    Yes, we tried unplugging it several times. Today we had it unplugged for over 8 hours and then plugged it into a different outlet. Initially it didn't work, but about 2 hours later it did work... I expect it will work for a couple days now, then not work again. We will see...
  • kruserz May 07, 2008
    Nope, it didn't work. It again has worked for several days, but today it doesn't.
    Please help! Another evening and the TV won't work again! It worked fine for 5 days, now it is doing the exact same thing it did on May 1st.
  • 156 Answers
Ok I can't be 100% sure on what exactly is causing this because it is caused by a few things. Ok the lamp yes could be the lamp I would start with that. Then I would try the Lamp Ballast. Then I would try the color wheel and the LDVS cable.... or last but not least the DMD board.
Now next time the TV works... check the LAMP counter. Please don't go tinkering around in the programmers mode.
Turn TV off and with the remote(not fast but not slow) press "Mute 1 8 2 Power"
Also when you replace the LAMP make sure you go into the service mode the same way"mute 1 8 2 power" and go down to the bottom to Options and reset the lamp counter.
I recommend that you change the LAMP... Its your call on going anyfurther than that please be careful.
Posted on May 07, 2008
  • Ronald Tisdale
    Ronald Tisdale May 08, 2008
    Also please write down the service mode settings before changing anything if your gonna tinker.
    Use [mute] and the [menu] button to move values up and down.
    Use the [volume +] and [volume -] keys to move to other adjustements.
    Use [add] to save the settings.
  • Bill Rider Feb 24, 2013
    I was finally able to get into the options mode but there wasnt a lamp reset, I did try to restet the hrs by hilighting the one item, hit zero and didnt get any response, went to service and tried that as well, no rsponse, what do i do now
    Brigadier General:
  • 3,614 Answers
Have you noticed or checked if the TV is overheating..? this cause in some parts to be in bad operation and resulting your television of in standby when the unit overheat..
Thank you & post back, and hear more info from you again
    Brigadier General:
  • 6,966 Answers
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Additionally, have you tried powering the unit using another outlet?
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
Posted on May 01, 2008
  • Louie  Role
    Louie Role May 02, 2008
    Appreciate the update. Will look forward to your subsequent post as to how it works out in another outlet.
    Cheers.
  • Louie  Role
    Louie Role May 07, 2008
    Have you considered using an appropriate voltage regulator?
2 Suggested Answers
  • 2920 Answers
SOURCE: Samsung HL-R4266W 42 shutoff
have the power supply checked it may be faulty
Posted on Oct 19, 2008
I have had my samsung hl-r4266w for about 4 years now and no problems until a couple days ago. I heard a loud pop, the picture color got all messed up and there was a loud buzzing sound from the time you...
IT SOUNDS LIKE THE COLR WHEEL HAS FALLEN APART AND WILL HAVE TO BE REPLACED. I RECOMMEND CALLING AN AUTHORIZED TECHNICIAN TO DO THE REPAIR. YOU CAN CALL 1-800-SAMSUNG TO FIND THE CLOSEST SERVICE CENTER
Aug 26, 2011 | Samsung HL-R4266W 42" HDTV-Ready...
I have a samsung model #HL-R4266W tv, It is making a humming sound, and has no color other than it being in black and white the picture looks fine, what could be the problem?
This tv design have a colors wheel in it,have humming sound or loud motor noises.The colors flashes Black&White or lost all colors.The colors wheel is dying and the causes.The colors wheel replacement are not a do it ur self project.Hire a tv Tech. to do it right the first time.Colors wheel sit way back close to the Light Projection Engine itself.
Dec 30, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung hl-r4266w
it is more than likely the bulb you can pull it and see if it is broke or looks bad if so replace first than go from ther
Jan 24, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
TV will not turn on. Lamp indicator light blinks
Replace Lamp (L3) # BP96-00826A (L6 )BP96-01073A Call Mats Electronics $99.95
1-800-628-1118
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
HL-R4266W white spots !!!!!!!!!!!!!!!!!!!!!!!!
Light Engine Call UED for price of rebuilt one 1-800-648-6657
Sep 13, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung HL-R4266WX 42-Inch
You need to check the SMPS(80%) or Main Board(20%)
( possibility ratio)
Nov 29, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Oct 19, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
217 people viewed this question
Henry  Thomas
Henry Thomas
