ZUNE HAS A PICTURE OF A BATTERY WITH THE LIGHTNING IN MIDDLE
    Problem Solver:
  • 14 Answers
Well that means its charging that happens when you pulg it in and im not quite sure becaue i dont have a zune but in like 99% sure thats what it means
Posted on May 01, 2008
I own an LG 42LB1DR-UA. After a major lightning and thunder storm last night, I see that there is no voice when watching cablevision which is hooked up with HDMI cable. When I use other cable [3 color], I...
Sir try to use a dvd and put a movie if your unit produce normal sound and picture the problem is the digital receiver. Good day and best regards.
Aug 19, 2011 | LG Televison & Video
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
i think all you have to do is let it sit like that for a while and if not try holding the middle button (if you have on on that) that worked for me before
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Blinking screen turning on and off
Mine does this if I let the battery get too low. In order to fix it I have to open the case, unplug the hard drive, plug the zune into my laptop and let the battery charge for a couple of minutes. I then turn it back off, plug in the HD again, replace the case, and plug it back into my laptop and it boots just fine.
I Imagine this means I have a weak battery (trying to spin the HD drops it below minimum voltage), but maybe this'll help someone else get up and running again.
Dec 14, 2008 | Microsoft Zune JS8-00001 Digital Media...
my 30gig was doing same thing i opened it up and one of cables just slipped out of port very simple to fix open you zune where the charger goes in there is a black cover remove this carefully then remove the 2 very small screws next use a very thin flat surface be very careful and you can see the edge where it seals just put you thin applient into the side and gently pull it up go all the way around once at top be gentle dont use the knife or whatever you used just slide it appart the back will come off then just reconnect cables good luck
Sep 30, 2008 | Altec Lansing M604 Computer Speakers
Hey my zune has a battery charge think but its a black screen
Reset the player - see the picture in the manual for the location:
http://www.zune.net/en-US/support/usersguide/default.htm
Jul 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Trouble charging my zune
I would say make sure you are in the right USB port. My laptop has 3 and only one of them will charge my mp3 player
Apr 12, 2008 | Microsoft Zune JS8-00001 Digital Media...
54 people viewed this question
 Grubhead
Grubhead
