My DX-C211 6 disc changer will not play as the discs are slipping on the spindle. In operation the motor lifts up collects the disc and engages with the small balancing plate above it. The motor turns but the disc does not. On intermittent occassions the disc will play , the full disc and then refuses on the next disc. What can be causing the slippage?
  • 2,334 Answers
The slippage is cause by the disc not being press firmly when it plays.
I would suggest to cut a small peace of rubber with a 0.5 mm thickness and apply it to the plastic that holds the CD. If that did not work, try with a 1mm thickness. After the CDs play normally you can add glue for a permanent fix.
Let me know if you need more assistance.
Posted on May 01, 2008
  • Jaime Hernandez May 01, 2008
    You can also try to move up the plastic CD holder for about 0.5mm and see if it plays.
    Genius:
  • 1,447 Answers
Rubber belts might need to be replace since it not fully grabbing gears to access disc function. Is it still within warranty? have it check cause mechanism are a bit complicated, cant really suggest that you dismantle it.
  • 3,037 Answers
It sounds like the disc isn't getting pushed down to below the little springs on the spindle, can you see the disc spinning at all, I would have a look at the tiny springs and try placing a disc on it by hand and see if there are any problems trying to lock it in place. you will have to take the cover off in order to get at this. Be careful not to touch metal components.
Also does it make any sound while the disc is slipping
thanks
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Wont spin or play discs
Two possibilities, The Spindle motor need lubrication or the unit is in such condition that the pickup can not focus on the disc. This happen if the spindle platter goes out of specs- they slip down mostly. The CD olayer wants to get a Focus OK signal before the disc is told to spin.
Sep 29, 2012 | Sony Mxd-d5c Cd Changer Rare
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Music plays normally at first then begins to cut out. The problem gets worse as the CD continues to play. RCA RP8070 Five Disc Changer. THANKS
There is a problem with the laser pic-up assembly(eye) 1st,2nd, 3rd,4rth music/track are recorded on disc from the center to edge.As the laser moves toward the edge the laser can't read perfectly the stored data on the disc. possible cause:the disc is in figure of 8, the lens needs cleaning, the suspension of the laser assembly,poor recording speed,spindle motor and voltage fluctuation of VCC
Sep 01, 2009 | RCA RP8070 5-Disc CD Changer
Discs not reading
first clean the laser lens,and if this not solve your problem change the motor disc spindle
Jul 13, 2009 | Onkyo DX-C340 CD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Cds
Could be the power supply not supplying enough juice to the spindle motor. Make sure it's not plugged into a "multi-plug" adapter.
Could be the spindle motor as well, or the disk sensor.
Let me know should you find something else...
Sep 21, 2008 | Technics SL-PD687 5-Disc CD Changer
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
48 people viewed this question
 Grubhead
Grubhead
