Question about HP Pavilion dv1000 Notebook
USB Ports are not working
I have HP Pavilion dv 1000 laptop which was purchased in 2005.
My 3 USB ports are not working at all. I had updated with drivers again but seems to be there is some problem with USB ports.
Request you to give me solution on the same.
Regards,
M P
    Genius:
  • 1,027 Answers
A USB device, such as a camera, scanner, or printer, loses its connection and stops working unexpectedly. The device may appear to work fine when Windows first starts up but later stops working. Use the steps in this document to resolve this issue. Disable power management on the USB hub To preserve power, Microsoft Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
If this doesn't help download everesthome. Run the program click on the chipsets and google the northbridge for updates.
Posted on May 01, 2008
My laptop is an HP Pavilion dv 8309us and when none of the 4 USB ports recognizes any device. A message appears "USB DEVICE NOT RECOGNIZE, ONE OF THE USB DEVICES ATTACHED TO THIS COMPUTER HAS...
I think the problem lies in a damaged USB controller on the laptop. The fact that none of the ports work, indicates that either the power to the ports has failed, or more likely the circuitry controlling the USB hub has failed. Sadly You will most likely need to replace the motherboard
Jul 18, 2011 | Pavilion dv8309us dv8310ca dv8310tx...
Hp pavilion dv1000. All 3 USB ports not recognising any device
go to device manager and from there try updating the usb drive from there
Feb 28, 2008 | HP Pavilion dv1000 Notebook
How cain i connect my laptop Hp pavillion dv 1000 to TV
you can purchase a usb device with TV outputs. look on ebay or purchase one from your local PC retail shop.
Apr 16, 2010 | HP Pavilion dv1000 Notebook
This usb device can perform faster if you connect it to a hi speed usb 2.0 port. I have an hp pivilion dv 6000, and according to the specs, I have usb 2.0, but I get this message every time I plug my flash...
This is just an error message. Yes, your HP Pavillion has USB 2.0, but there's a possibility that your USB flash drive has USB 1.1 specs.
If the flash drive has USB 1.1 specs, you would still get the same message. Again, this is just a message because USB 2.0 is backwards compatible with USB 1.1.
Have a great day!
Oct 10, 2009 | HP Pavilion dv6000z Notebook
Usb ports not working
buy a new mother board or use recovery media after saving files and clean out usb ports
Jun 13, 2009 | HP Pavilion dv9000z Notebook
Need to replace usb ports dv1000
If the problem is with the ports themselves, you may not be able to or be willing to resolder them. How about just adding a USB card to get by?
Jan 24, 2009 | HP Pavilion dv1000 Notebook
USB ports not working DV 1000
i need more details cuz i can not understand what the problem really is, is it with the hardware or software... please rewrite your problem
thank you for your corporation
Dec 16, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I just fixed this problem on my dv1000. The problem I found was apparently the USB ports on lower right and left side only mounted on the mobo with light soldering and no soldering on the other side of mobo. Due to heat I guessed, they came loose. I opened the mobo (using guide from a pdf file on the net, sorry i forgot the exact guide but you can ask uncle google).
I took the mobo out and resolder those two ports with plenty of solder from the top surface only of the mobo as I unable to access the other side. Now they work again like charm.
The top right USB is different beast. It is on different card along with S-Video port and apparently in permanent damage.
Dec 06, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
343 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
