Question about Bosch Axxis WTL 5400 Dryer
Bosch wtl 5400 elect. condensation dryer
All of a sudden the dryer wont start. All the power lights are on and such it just wont start. Anything i can look for before calling for help All of a sudden the dryer won't start. The lights come on, the filters are clean, but the dryer won't start. Any ideas what is wrong?
    President:
  • 2,712 Answers
Hello joeychacha,
Since your dryer is not working at all, I would check the following components:
1. Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms. NOTE: If the thermal fuse is blown, the drum light will not come on.
2. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
3. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
4. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
5. Bad Timer - If the timer does not function the dryer will not start.
6. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
7. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
Also check the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint.
If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side. CAUTION: It is recommended that you unplug the dryer BEFORE servicing the inside or cleaning. There are still dangerous voltages present even with the machine turned off.
Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please close the ticket with a FixYa! rating under my solution.
    I
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
  • 3,037 Answers
Does it make any sound like it is trying to run. You could open it up and possibly check the belt
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
Door latch is broken. Door wont close. Is it possible to buy replacement door?
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Jan 10, 2011 | Bosch Axxis WTL 5400 Dryer
WTL5100 won't tunble. Condenser water light on but
Make sure the condenser is pushed back in palce correctly. If tghe eoor persists then tun off the AC power to the machine and wait for 30 mins. Then power it back on. The fault should clear but of not then you may have a fault with lelvel switch
Nov 10, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch WTL 5400 running, but not heating
I've just fixed mine. The heating element at the rear under the covers was broken - crappy design BTW!
Mar 18, 2008 | Bosch Axxis WTL 5400 Dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
505 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
