Question about Refrigerators
The motor on my Sanyo Mini-Fridge goes out every 3 to 4 days. The previous surge protector it was plugged into shorted, and I think that may have something to do with it. What is wrong? It will work fine for 3 to 4 days then the motor will continually try to start, but will never fully turn on. I have to leave it unplugged for about a half hour, then I plug it back in and it works.
    Scholar:
  • 149 Answers
Defective relay/overload combination if you replace them and it works, there's you problem, if you replace them and the problem continues, suspect a faulty compressor.
Posted on May 01, 2008
Had power surge. Tv was on surge protector. Now no power will come on and just makes a buzzing sound.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Oct 25, 2012 | Televison & Video
Can i plug a mini fridge into a surge protector?
you must check the amper ( current) rating as will as wattage of the mini fridge usually at the back portion. if the current and wattage rating of the surge protector is higher capacity so it can hold this fridge.
Oct 02, 2012 | Emerson White Compact Fridge - 1.8 Cu. Ft
Hi, have a magic chef MCWC16MCG. I plugged it in to a a receptical and it wasn't working. Due to limited space I used an extension cord and a 3 prong adaptor (live and learn) so I could get it to a...
the extension cord must be # 12 wire size for better and the gorund should not be removed . ( proper polirty is important . ) do replace the start relay and if you have a ohm meter ck it for open or short to ground before installing the relay . ( good power is best ..or a short compressor life is for sure .. mm
Aug 11, 2010 | Magic Chef MCWC16MCG Wine Cooler
Sanyo SR-3660 Mini fridge doesn't run
How long was it in storage?
A fridge doesn't like to be laid down then stood up and plugged in. Reset the overload circuit.
Aug 07, 2009 | Refrigerators
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Surge protector shuts off while playing PS3
swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
My HP HDTV trips my circuit brakers
1) Try with a different surge protector. The oine you're using could have a short-circuit
2) Try without a surge suppressor, at least for a day
3) Does the circuit breaker trip when something else starts running? Your microwave, fridge, dishwasher, etc.?
4) Check the user's manual of your TV, under SPECIFICATIONS. Check for "POWER REQUIREMENTS". If the power requirements listed is greater than 15 Amps or 1,700 Watts (assuming you live in the USA and your household is 110-120V), then the circuit breaker will almost always be triggered by the TV. Most circuit breakers inside a house are 15 Amps.
The only option you have is to replace the circuit breaker for one that has more Amps, but doing so on your own without having and electrican check if the wiring will hold the extra load is extremely unadvaisable. You may end up with an electric fire in your hands.
May 29, 2009 | HP PL4260N 42 in. Plasma HDTV
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
HD TV flat screen
there is a timer that you can set to turn the tv off automatically. The timer settings is between 30 min. and 3 hours, maybe she has hit the timer button by mistake.
May 31, 2008 | Televison & Video
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
