Question about RIM BlackBerry Pearl 8100
How do you load more tape in the brother lable maker model: pt-65
  • 42 Answers
Here is the manual:
http://www.ptouchdirect.com/ptouch/manual/PT65.pdf
Look under "changing the tape cassette"
Hope this helps. M~
Posted on May 01, 2008
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
How do i load tape in pt 65?
Remove back cover by pressing down on dots. Make sure you have the correct size replacement (they start with an M and are 9mm or 12mm).
Put the side of the tape that has the open V in it over the silver metal holder in the PT65. Snap the left side of the cartridge in. This should line up the black roller with the exposed part of the tape.
Snap the lid back on and turn on the unit. Hold the CODE button and press the space bar so some of the tape feeds out of the top.
Apr 23, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
How to load the tape in the label maker
www.ptouchdirect.com/ptouch/umpt65.html - 30k -
Feb 25, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
How and where do I feed new labels
press and hold the code button and press the "space button" this will feed the tape
Feb 18, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Dies in the middle of printing lable
Yikes!
It should behave after getting fresh batteries! (They were brand new just out of the package batteries, right?)
If the cartridge is seated down correctly and there is no junk or old tape in the way, then I don't know what could be causing it.
Might be time to call the Brother Help Line at
1-877-478-6824
and see what they say.
Jun 12, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
