Question about Polaroid PDM-0711
Screen is off to the side and has lines running through it
I used my DVD player last year in an airport, it worked fine. I got on the plane and turned on my dvd player and there was no image on the screen... finally after just listening to my movie.. I opened it up and ever since then I can see half of the screen and there are a million lines running through it... I never dropped it or anything within those 5 minutes. My warranty ran up that month... is there anyway to fix this?
  • jess5315 May 01, 2008
    thanks, i appreciate it.. There is no physical crack in the screen. Maybe a lot of pressure was applied to the screen and i did not know it.if i push on the screen it does change what the image looks like.. i guess it cant be fixed then. thanks though
    Scholar:
  • 79 Answers
Usually when you have a million lines running through the screen it means the screen is cracked and you have to replace the whole screen. This usually happens when you drop the product or maybe you put it under something that applied alot of force on to the screen. Try to think back and remember if you placed it under alot of pressure at any point. This may have bent the screen enough that it became permanently damaged. Another theory is if you moved the player around alot that the cable that connects the screen to the rest of the player may have come loose. I know that this is a portable device but it can still happen. If you decide to open the player up to check the wire be very careful because the cable is usually paper thin and can break very easily. Lastly it could be that the screen just failed though this is extremely unlikely because they usually test the screen very extensively before it leaves the factory and if it worked there it would most likely work for a long time provided no external factors such as dropping the player occur.
Hope this helps!
Posted on May 01, 2008
A plane is 48 miles west and 49 miles north of an airport. The pilot wants to fly directly to the airport. What bearing should the pilot take? Answer should be given in degrees and minutes.
Draw the airport. (X marks the spot) Draw the distances from the airport (to scale) to indicate the position of the Plane. Use a protractor to work out the correct angle.
To Calculate:
a=48 b=49 Angle= Tan-1(a/b)
Sep 25, 2013 | Cars & Trucks
I have an 11 year old Toshiba DVD player. The last 2 times I rented a disk I had problems. Everything seems to be fine through the previews. When the movie starts to play, the screen goes green. The audio...
This is usually an issue with the component cables running to the TV. Remove the cables and retry with different component cables. If this doesn't fix the issue, its a problem with the DVD player itself.
As far as DVD players go, you've done quite well keeping yours going for 11 years. A cheap DVD player at the local big box electronics store here costs about $30, definitely not breaking the bank getting a new one.
Mar 07, 2011 | Televison & Video
What does "line in" mean? I can't get anything on the screen except for those two words. It worked fine until we recently traveled and was checked at security. Could this have anything to do with it?
Line In means you can hook any other video source with this player to watch it on its screen.
There is switch at side of player, turn it to other side to watch dvd picture in this player.
Hope this info will help you.
Thanks.
Feb 17, 2010 | Sony DVP-FX810 Portable DVD Player
I bought a Portable Dual DVd Player (PLV31199S1W) last year from Targer and now there is no picture. WE tried everything. Can we return this. Thanks, Ginger
Check the side of the player, there is usually a button that takes the picture from the screen to the side port where you can run into the regular tv monitor.
Nov 27, 2009 | TruTech PVS12701 Portable DVD Player
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
Airplane interference in converter box
have you tryed moving the ant. to another place in the home? if it still does it you may need an ant. with a fm trap on it. this will get rid of some problems like this. hope this helps............
Nov 22, 2008 | Zenith C27A24T 27" TV
Error code h07
Panasonic DVD player spindle motors have bearings that are inadequately lubricated. After disassembling the case, which can be tricky, it is possible to deposit a drop of fine oil (sewing machine or equivalent) on the bearing to free it up. Allow a single drop of oil from a toothpick to run down the shaft into the bearing. I've fixed mine twice this way. Each time it lasted several years.
May 05, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Polaroid PDM-0711 Logo
193 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
