Question about Kenwood Car Audio & Video
CANT FIND KENWOOD AMP KAC-646X
CANT FIND
    Problem Solver:
  • 30 Answers
How can i help u ? what is it that u r looking for and need ?
Posted on Jun 23, 2008
No plug for kenwood amp kac-920
these people are idiots i am having the same problem with my 1020 i cant find one anywhere i am about to just go to radio shack and buy the clips and some wire and just by-pass it i have been looking for a couple years now and even my friend that works at a car audio place can not find me one
Feb 06, 2012 | Kenwood Car Audio & Video
What size amp is the kenwood KAC-9103d amp
im not sure what you mean by what size amp....whether you mean physical size or wattage (power) so I have provided a website link for all the specifications that you require..........
http://my.kenwood.com/Car_Entertainment/Power_Amplifiers/KAC-9103D
PLease vote if you liked this response....
Aug 20, 2010 | Kenwood KAC-9103D Car Audio Amplifier
When I turn up the volume the amp shuts off and displays an E-03
do you have your subs wired down to 1 ohm? The reviews on this amp is not very good, a lot of people said they had a lot of problems with this amp, a lot of blown fuses and cant take a 1 ohm load
May 12, 2010 | Kenwood KAC-X1R Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
What does it mean when the power light blinks on the amp?
genrally kenwood amps are power hungry amps so after playing for a while if it doesnt get the amount of amperage to make it work it will shut down cus you car cant charge the battery long enough for the use of that amp so my idea is try a farad capacitor and see if that helps good luck .......tk
May 29, 2009 | Kenwood KAC-7252 Car Audio Amplifier
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Cant get but one side to work
This amp (kenwood  819)  was designed for use with a sub-woofer, hence the single chanel. It will however power up 4 speakers in mono, and if they are capable of handling the amps.while robbing you of the benefits of stereo as well as left, right and fade control.Good luck...
If you still want it connected. You should purchase an amp installation kit, and review the topics and videos at this web site. www.installdr.com
Good luck...
Feb 24, 2009 | Kenwood KAC-819 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Car Audio & Video Logo
259 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
