Washing machine is not draining, coming up with a code LD
  • Anonymous Jul 22, 2008
    I can get the filter out. Do I just pull it or do I need to turn it.
  • 487 Answers
I think your filter or drain pump is plugged.
pull out your filter ( keep a lot of towels handy) in front of your machine and clean the filter. Look if you can find the obstruction in your pump through the filter opening otherwise you will have to dismantel the pump.
This should work
Posted on May 01, 2008
  • Whitneyo Nov 28, 2010
    We are having the same problem. Where is the filter? How do we access it to clean it?
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Washing machine not draining, LD error code
Through the lower tube of the tub may be able to remove the item of clothing.
Dec 22, 2013 | Kenmore HE2 Washing Machines
Gets to 8 minutes but wont go into spin cycle code ld comes up
  1. ld means long drain. If it takes too long to drain it won't go into spin or other cycles. It's possible that you have a blockage in your drain hose or pump, or your pump has gone out. Remove pump and check for any blockages. Replace your Drain pump if it is found to be bad.
  2. Also, some washing machines have a pressure sensor that can fail causing the ld code to come up.
  3. Last but not least, if the drain pump was replaced, and hoses were unclogged, and you still have the same problem, your control board may have failed.
Feb 25, 2011 | Whirlpool Washing Machines
During the wash cycle, the washer started beeping and I found a code "LD" on the dial. What is the problem
Here is what the manufacture says about LD -- my comments will follow
Long Drain
Ld flashes when the water level does not
change after the drain pump is on.
ô Is the drain hose or the drain pump clogged?
ô Is the drain hose height greater than 96"?
ô Is the pressure hose connection from the tub
to the machine/motor control pinched,
kinked, plugged or leaking air?
Phil's comments ---->
Almost always this code is due to a plugged drain pump or hose, it is especially common when washing a rug with a rubber backing that comes off or small articles like baby socks that get caught in the drain system of the machine. Depending on how adventurous you feel in taking this unit apart is your call, but due to the complexity of it I would recommend calling a service expert.
Just one guys opinion..
Apr 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD mean?
It isn't whether the water drained out, it is how quickly the water drained out. Common causes of the LD or long drain fault code are a kinked drain hose or some article of clothing being caught in the pump suction hose and increasing the time that it takes for the water to drain. It has to do with the cycle timer. I would look for some sort of obstruction. Also check the pump impeller for broken/missing blades and that it spins freely. If not, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 23, 2009 | Washing Machines
The code LD is showing
ld it a long drain check drain pump
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
230 people viewed this question
Top Washing Machines Experts
