What is a 32 inch tv V7? So I can adjust my ct-urdc6 remote.
  • marcel411 Jul 23, 2008
    je voudrais avoir la programmation de ma télé commande CT_URDC6. Merci
Programming:
1- Power on Equipment
2- Press SET until device light blinks
3- Press the device button
4- Press the UP or DOWN every 2-3 seconds until device turns off then
5- Press ENTER button
Gilberto
Posted on Apr 25, 2009
I cut the tv off with a universal remote and now it won't come back on??
Its a 32 Inch Panasonic ( indicated here) a lot of these were Famous for the 6.3 amp glass line fuse inside blowing for no reason.
Make sure if the fuse is bad get a good one and not a generic from Radio Shack--------Let me know if you have questions.
Mar 15, 2012 | Panasonic CT-32HXC14 32" TV
I HAVE A TOSHIBA REGMA 32 INCH. WILL REMOTE NO CT-90251 WORK FOR IT?
I lost my akai dvd player remort control model no. dvx 501. how can i get new one
Dec 23, 2009 | Toshiba CT-90251 Remote Control
Blue lines appeared near lower half of screen
Hello... This sounds like a convergence issue, but I didn't think they made rear-projection TVs as recently as 2013? Also, your post says you have a 32"? If it's a 32", then ignore the following.
If it is a convergence issue, parts will need to be replaced. There are usually two STK ICs and maybe some resistors that can go bad.
I hope this helps!
Nov 24, 2017 | Panasonic CT-32HX41 32" TV
TV does not power up
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
Feb 14, 2008 | Panasonic CT-36SL13 32" TV
Toshiba 32 inch tv made1990
yes,you can adjust it by your remote control,find the service menu and from there you can now adjust the vertical from of your tv.
Oct 30, 2007 | Toshiba 32AF43 32" TV
Panasonic CT-36D31E HPOS problem
1. Press the ACTION button on the remote control to display Main Menu. 2. Press the CH up/down or VOL right/left button to highlight the desired icon. In Picture menu under VIDEO ADJ. select: NORMAL - Reset all picture adjustments to factory default settings. Good luck!
Nov 28, 2005 | Panasonic CT-32D31 32" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
