Maytag washer will not agitate
My maytag washer will fill with water, but when I put the lid down nothing happens. no agitation at all. I replaced the lid switch and fuse and still nothing. My belts seem a little worn but I don't know if that is the problem.
    Genius:
  • 1,028 Answers
Ckd wiring connections motor and timer? if they look ok suspect timer ..motor contacts in timer may be shot
Posted on May 01, 2008
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
