Question about Olympus P-11 Thermal Photo Printer
When I try to print to my laser printer MF4150, it prints one copy and the error light comes on and ithas LOAD CORRECT PAPER CASSETTE :A4 I pulled the paper out and reloaded. I Looked in my BASIC GUIDE book on page 3-7 to Setting Paper Size and Type and did that. Then when I try to print the same thing happens over again
  • 1 more comment
  • Anonymous May 25, 2008
    I have the same problem. When I try to print pdf documents (I have not tried any other type) it prints one page and stops printing. The error says that I need to load the correct paper: LTR. I use the correct paper already. I've played around with this on so many different levels and nothing works.
  • shyuan1977 Jun 24, 2008
    I am getting the same problem now. Trying to figure it out.
  • Anonymous Oct 17, 2008
    I have the same problem printing from almost any application. It will print a few pages then say LOAD CORRECT PAPER. I just hit the OK button and it usually reprints the last page, and spits out an extra blank page then contiues. I think it does not like the cheap STAPLES paper? I will try some heavier paper but this is rather annoying....
Go in (win xp)
control panel
printers and fax
right click on the printer giving problems
click on properties (down the list)
click on printing preferences
on page size, switch from A4 to letter
click OK
Have a nice day
Posted on Sep 22, 2008
I think this is Canon's problem. I am also facing the same problem right now!!!
Posted on Jun 26, 2008
Need some more details here.. does this happen when you try to print anything or just a certain type of document?
i have seen this a number of times when the normal.dot template in word or specific word documents have a different page setup is specified.
Posted on May 01, 2008
Just follow what the above guy said it worked for me
Posted on Apr 23, 2009
The red light is on and appear this message: LOAD CORRECT PAPER CASSETTE. What should I do?
if this happens when you send the print job, you need to choose correct paper size under the printer properties on your pc.
Go to the printers, choose your mf4150, right click and properties, under tab preference, under page size choose correct one i.e. A4.
Turn MF off and back on and try again to print
Aug 04, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Bought new laptop OS window 7 64 bit. Major problem with getting the printer to print properly. Downloaded & installed MF4100_MFDrivers_Winx64_us_EN_7. Each time i test print this error comes up...
Hi! Please try to download the printer driver that is compatible with windows 7 64bit. This may be the problem thats why the printer fails. Hope this helps and thank you for using FixYa!
Sep 19, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I bought canon printer MF4150 from Singapore. The problem is when i print or photo copy A4 or legal size after 1 printer it errors and said load proper size @ MP tray
The printer may have a setup for a region which will change the paper size. Also the paper tray may need to have the paper size adjusted on it physically. Save the paper size in the preferences to A4.
Nov 17, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I can only receive one page each time
Make sure that the paper size set on the machine matches the paper that you have in the cassette. Also make sure that the sender is not sending legal-size documents if you are using standard size paper.
Is the machine giving any type of error message or code when the error light comes on?
May 15, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Olympus P-11 Thermal Photo Printer Logo
628 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
