My screen turned completely green when i switched channels.
  • Anonymous Nov 11, 2008
    me too. my screen just turned green when i turned my computer on and i dont know y plz help.
Screen turned completely green while switching channels
Posted on Sep 29, 2008
We have lost our digital channels on our sharp aquos. how can i get them back. ex. 5.1, 5.2, 17.1 etc
Remove the coax cable from the television
Unfortunately your digital tuner may have gone kaput. I hope not but try an init and then rescan the channels. Unplug the television. Press and hold down input and vol-. This might take two people. While holding those buttons down on the television NOT on the remote have another person plug the television in. Keep holding down on those buttons until there is a k (green) on the left side of the screen. Then release the buttons and hold down vol - and channel - until the service menu comes up on the screen and release the buttons. Scroll down once with your down arrow on your remote until you are on page 2/26 (might be 2/some other number besides 26). The press the right arrow to turn on INIT + cause on. Press enter. When the screen turns green unplug the television without powering it down or anything. When you plug it back in it will prompt you back through the setup process.
Replace the coaxial cable before completing the setup.
If you do not have this exact model number do not complete the steps above without consulting again with the correct model number because you can wipe the memory of the television if you do not complete the right choices to bring up the service menu.
Dec 04, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
My 50" panasonic tv screen goes completely green I turn off tv and restart and the picture is still great, but it is doing this more frequently
my 50' panasonic some channels are in another lanuage then some channels have no volume the people mouth are moving but no words then some channels are good.
Oct 03, 2010 | Panasonic TH-50PH9UK 50 in. Plasma...
The tv was working fine the other day. I turned it out today and the screen just stays black. If I press the channel button up or down the channels change and sound comes out. The audio works fine, but the...
Turn it off/on a few times within a few mins each times.U get a flashes of picture about 10 to 20 sec?Than ur LCD inverter board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It usally a long PC board in shape.
Apr 16, 2010 | Polaroid FLM-3232 Television
Screeen
If it's a big tv it can just take a little while to power up, I've found that pushing channel up button switches on tv quicker but I've no idea why.
Unless you want to save power you should only be switching tv to standby, there will still be a light on the tv somewhere, blue or red it varies. TV's turn on much faster from standby than completely off.
Jul 23, 2009 | Samsung HLS4666WX 46" HDTV
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Green colour prominent when viewing and on blank screen
This problem just resolved itself after TV being left on for an hour ????? Probably will need looking into anyway.
Jan 25, 2009 | Sharp Aquos LC-32D40U Television
SNES problem
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
Slide the Power Switch on the Control Deck to the ON position.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Aug 23, 2008 | Nintendo Super NES Console
Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jun 10, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Polaroid FLM 2011 Green screen
Mine did that too for a while. I called polaroid and they told me to leave it unplugged for about 10 minutes   and then plug it back in.. I did and it works fine/has ever since. Supposedly that problem is caused by a week cable signal? Try unplugging the tv to rest it before you spend money on it.
Aug 31, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
