Broderbund PrintMaster Gold Version 18 Logo
Posted on Aug 16, 2010
How can I bring the watermark to the forefront layer instead of being hidden behind the images?
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
1714
Points
48
Use publishing software that isnt ****
2answers
Can I create a watermark on my picture in picasa
The best way to add a date/time stamp or another watermark to your photo is to use watermark software like Bitwar Watermark Expert.
Add Watermark
So users need to download and install the best watermark software on the computer system first. Then, users can choose Watermark Photo or Watermark Video tool based on the required file format but the steps below will show how to add watermark to photo:
Step 1: Choose the Watermark Photo tool and upload the image file into the software.
Step 2: Choose Add Text to add text watermark or Add Image to add image watermark to the picture.
Step 3: Type in the text into the textbox as text watermark and edit the watermark by editing the Font, Size, Rotate, Opacity, and Position. Besides, browse the Image to insert as image watermark and edit the image through the Size, Rotate, Opacity, and Position.
Step 4: After finish editing the watermark, click Apply to start the conversion.
Step 5: When the conversion is complete, tap on Open Path to preview the new photo.
May 25, 2016 • Cameras
2answers
How do I place a watermark on a photo with photoshop?
0. Paste or create a layer over the top of the 'main image'.
1. Select the layer you want to be the watermark.
2. Change opacity to what you want, ensuring you can still see the layer underneath it.
Note: you could also change the blending on the watermark layer if you wanted a different effect.
2answers
How do I remove a watermark in Adobe 7?
go to insert->picture->impression check on remove watermark option
5answers
Remove date stamp from photos
The best way to add date/ time stamp to your photo is to use watermark software like Bitwar Watermark Expert.
Add Watermark
Step 1: Choose the Watermark Photo tool and upload the Image file into the software.
Step 3: Type in the Text into the textbox as text watermark and edit the watermark by editing the Font, Size, Rotate, Opacity, and Position. Besides, browse the Image to insert as image watermark and edit the image through the Size, Rotate, Opacity, and Position.
Dec 08, 2009 • Cameras
Where is the dodge tool?
Dodge tool should be on your toolbar- its like a black circle with a little line coming down diagonally from it- shares a button with sponge and burn so may be hidden behind them. Left hold click if it is that should bring up a little drop down that will let you select the tool you need.
Other than that, a much much better way to dodge/burn is to use layers- go to layers (top of the screen beside file, edit, etc)
select new->layer- this should open a box.
Now- set the colour drop down to none
Mode drop down- Set to soft light, feel free to experiment with hard light etc
Tick the soft light neutral colour (50%grey) box- should be at the bottom of the box.
Set opacity to somewhere between 5 and 10 %.
Click OK
This puts a new layer over your image, now you can use the paint brush- set your colours to black and white, you use white to dodge black to burn.
Though this may sound complicated, it soon becomes second nature once your used to it and gives you alot more control of your dodging and burning- leaving you with a much more 'natural' image. Once you get the hang of it you can add new layers (using the same process i went through above) to slowly build up your dodging and burning- changing the opacity level in the layer box to a higher setting means you put more paint on the image- your burning will be darker, dodging lighter.
Using mulitple layers also allows you to take away a dodge layer if you think you have gone to far- and saves you stepping backward when you mess up- its almost like painting.
3answers
Watermarks
MS Word: Page Layout tab on the Ribbon, Watermark button, in the drop-down select Custom Watermark...
Is that what you were looking for?
7answers
Date/Time stamp
Add Watermark
2answers
Text in CS2
Dear Roan,
It may be because your text is behind the background. That's what was happening to lots of people trying to use Photoshop CS2. Try going to Layer--then Arrange--then bring text to front.
This has worked for most of the people has fixed the problem. Hope thats helpful. If you still have problems you can go read the forums and also can access the help file in software's Help menu.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
