Question about LG VX8300 Cellular Phone
Clock I turned off my phone today, and when I turned it back on the clock was missing. I tried turning it on and off, and even took the battery out. I also went into settings and made sure everything was on, but still no luck. Any suggestions?
  • LGuser May 01, 2008
    I tried that already. I just look at my world clocks though, and they are all the wrong times...
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
Try the settings and find the clock setting to turn it on.
Posted on May 01, 2008
I have the S1721 Travel Soother Radio Alarm Clock. It has stopped & a radio technician said it can't be fixed. It is THE best radio on the planet because it has a radio timer. I cannot find anything...
I came home and found a weird display showing 12 00 and ______f. Nothing worked, even when I unplugged it and took the batteries out. (I really, really like this clock radio so I wanted to find a solution).
I looked for a "reset" button and found one in the back inside the battery case (you have to remove the battery case cover). I took a pin and pressed it into the reset slot. I had to do this several times, turning it on/off and pressing several buttons and plugging, unplugging the clock/radio. It cycled through several times, then slowly the functions started to return, almost one function at a time. After several cycles of this, it turned itself back on and started working again!
Dec 01, 2010 | Sharper Image Travel Soother 20 Clock...
Turn signals stopped working now no power
I concur this is a power supply fault of some sort, insure your battery connections are maintained, meaning clean and good of contact, obtain a voltmeter and test the voltage at the battery contacts it should be about 12.5 or higher, turn the key on and try to start, noting the voltage, if it drops below 11 volts, there's your fault if not a poor ground from the battery and the frame of your vehicle may be faulty but boosting your vehicle from another sports battery fault
May 05, 2010 | 1998 Plymouth Voyager
Have you tried to delete ALL calls, not only the missed ones?
Hopefully the screen will reset if you delete all calls, both incoming and outgoing ALL calls.
Another way may also be to temporarily change the Today screen. Go to settings and click the Object tab.
Uncheck all and save your changes.
Go to the today screen and se that everything is gone.
Optional-You may turn off and on your phone and remove the battery for a few minutes and then turn on your phone again.
Now you can try to change the Today screen back the way you want it.
If this do not solve the problem and you find this hilly annoying maybe a total reset of the phone may be of help. The problem is that it resets everything, therefore you need to backup everything you don't want to lose, but this will sometimes solves strange problems.
Mar 01, 2009 | LG KS20 Smartphone
Will Not Turn On !
your phone is water damged and has commonly soked in the test points. send this in as its a common manafacture fault as the new boards test points are covered and stops water damage.
Jul 28, 2008 | LG KU990 Viewty
My phone will not turn on!!!!!!!
Try removing the battery overnight. Then put the battery back in and try to turn on.
May 20, 2008 | Sony Ericsson Walkman W810i Cellular Phone
I have the exact same problem please tell me how to fix this i had the phone for less than 24 hours and it wont turn back on i can see the send and end buttons light up but nothing happens ... i took the battery out of the phone cuz it froze on me and it wouldnt allow me to do anything but now after i did that it will not turn on is there any kind of way to fix this.?
Mar 10, 2008 | LG Prada KE850 Cellular Phone
Won't turn on, may need SIM card help
The phone you have does not have any sim card. I am not sure if your phone provider will allow you just buy another CDMA phone and just transfer your number to it. I know alot of phone providers in US allow this though. About your phone there might be a loose component thats why when you play around with it, it worked then shuts down again. i suggest buy a new one CDMA phones are cheaper than GSM phones though.
Feb 08, 2008 | Motorola Mobility V325 Cellular Phone
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
Wont Turn on
while charging your phone try to switch on your phone .or just try to switch on and switch off your phone 3-4 times continiously even if dosent work take it to the authorised service center
Dec 26, 2007 | Motorola Mobility V365 Cellular Phone
LG VX8300 Cellular Phone Logo
32 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
