Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Cold Water runs constantly even if the washer is off
I have a Whirlpool Ultimate Care II washer. A few days ago, the washer began running over in the rinse cycle. It appears that the washer will work if the cold water is turned off at the faucet. If I turn the washer off and/or unplug the washer and turn the cold water faucet on the water runs into the washer. Any ideas on how I can fix this? I'd like to fix this without having to buy a new washer.
    Genius:
  • 1,028 Answers
You will need to replace fill valve where hoses connect probably has sand in valve especially if screens have been removed remove screws in rear of console lift and roll console back disconnect wire to lid switch remove clips om right and left rear corners cabinet lifts off disconnect hoses and wires 1 screw usually holds valve in postion
Posted on May 02, 2008
Whirlpool LSL9345eq0
Hi i dont think it is a train smash, Whirlpool normally have a cartridge fuse in the wiring harness. You will need to open the top panel and look inside the cover and you will see the fuse assembly. Open it and confirm the faulty fuse. Replace and test. Make sure no water is present on retest.
Jun 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The cold water runs continuosly. If the water is turned on it runs even if the washer is turned off.
This problem involves the water mixer valve.
Not shutting off.
You have to replace and problem solved
Its the valve that the hoses attach to in the back of the washer.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Nov 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
Good luck
Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Softener getting all over top rim of washer
i tell people to dilute it with water so it is not as thick.
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Have cold water but no hot water
try turning on both taps and see what happns,some of these whirlpool machines need both taps on but mainly when running on cold.
Mar 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
158 people viewed this question
Dan Webster
Dan Webster
Sal De
