Question about Vacuums
Over heats and blows dust out the back, and wont pick up
    President:
  • 1,673 Answers
You most likely have a clog in the dirt inlet by the brush roll or in the hose. It will overheat and shut down when this happens.
Posted on May 01, 2008
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Wont pick up anythimg
Check your pick up tube. Use a straitened wire hangar to push up tube and check blockage. You also may need to change the bag. Some bags sides will clog with fine dust and reduce the suction.
Jan 03, 2016 | Bissell Steam and Sweep Hard Floor Cleaner...
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
My steamvac wont pick up the water. it is spinning and blowing out the water, but it wont **** it back in
The most common reason for lack of pick-up is that the lid is not seated firmly on the recovery tank. Lack of pick up is always caused by an air leak. A less common possibility is that the large round rubber seal that the recovery tank sits on has fallen out of place. If you look at the bottom of the tank, you will see a round hole. When you install the tank, this hole sits on top of a rubber seal on the motor shell. Be sure the seal is in place.
Feb 05, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Blowing insteading of sucking
Go online to HOOVER.com and locate your nearest repair facility. Take receipt with you to show it's a new purchase.
Feb 05, 2010 | Vacuums
It is blowing dust out of the motor
If this is a bagless machine, then the problem is that the really fine dust that you are picking up from your floor is so small that it is going through the filter and dust cup and building up in your vacuum motor. When enough build up collects, then it starts to blow it out the exhaust. I would bet a paper bagged machine for the long run. They are cleaner,
Nov 28, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dust blowing out of the side of vacuum
make sure that the filter in the dirt cup is in place.
Dec 30, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
