What are goals of Ge Energy - Audio Players & Recorders
  • 979 Answers
Have you notice what forum you are in?
Posted on May 01, 2008
Ge profile side by side sweating on frig wall next to freezer
Your fridge may have an optional energy saver switch set to on. This turns on & off the heater strips along doors and other key locations.
When set to ON (or the Energy Saving position), energy savings is realized as it powers down the heaters that are designed to evaporate the condensation that can naturally form there - especially in warmer / humid weather conditions.
Slide the switch to OFF to to disable energy savings and have to pay for additional power to operate these heaters. You may find that you need only select this position at certain times of the year. Experiment to see if you can enjoy savings during the other times of the year.
Play the video below for additional help.
Energy Saver feature explanation
Mar 24, 2015 | GE Refrigerators
GE Energy Star WCVH6260F drum removal
unless you are a service tech you dont want to try that, big job takes 2 people that knows what they are doing a couple hours to remove and replace. call for service if under warrenty, if not your looking between 500 and a 1300 to repair.
Jan 02, 2012 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Mar 14, 2010 | GE Energy Star WCVH6260F Front Load Washer
Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
G e energy star
THE GE WASHERS HAVE A PUMP FILTER BEHIND THE LOWEST PANEL ON THE FRONT. ON THE FRONT OF THE MACHINE AT THE VERY BOTTOM, REMOVE THE THREE SCREWS TO REMOVE THE BOTTOM PANEL AND YOU WILL SEE THE ROUND PUMP FILTER HOUSING. IF ON A PEDESTAL, PLACE A BUCKET IN THE DRAWER AS WATER WILL COME OUT WHEN YOU UNSCREW THE FILTER. IF ON THE FLOOR, TILT MACHINE BACK A WAYS TO GET THE WATER INTO THE BACK OF THE TUB, NOT TOO FAR OR IT WILL COME OUT OF THE REAR VENTS. REMOVE FILTER AND CLEAN OUT. THIS IS THE PROBLEM MANY TIMES.
Jan 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
21 people viewed this question
 Grubhead
Grubhead
