I have a logitech wireless music system. It all works fine however I can not get the remote to work! If i press the buttons on the receiver it works fine but the fame functions on the remote do nothing? I have checked the battery and its fine as well
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
Open the remote and try to fix the inside.
Posted on May 01, 2008
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
I have a MX 3200 Logitech wireless keyboard and mouse combo. the wireless mouse works fine but the keyboard does not respond. The multimedia buttons work fine such as the scroll wheel on the side and the...
have you tried pressing the button on the back of the receiver then press the button on the bottom of the mouse, then press the button on the back of the receiver again and press the red button on the back of the keyboard
Sep 01, 2010 | Logitech Cordless Desktop MX3200 Laser...
Mouse will not work. I've changed batteries, unplugged and re-plugged the remote device. It will not work. What do I do?
Have you tried pressing reset/connection button on the device? Some Logitech models may have a connection button on the receiver which is plugged into the computer. The receiver button must first be pressed then press the device (mouse or keyboard) reset/connection button. Some Logitech models you will have to go into the Logitech software to start the connection software then press the reset/connection button when prompted.
Aug 13, 2010 | Logitech Wireless Access Duo Optical...
Using the soundlink wireless music system. was working fine. suddenly, both aux light and wireless light are on. not getting sound output from PC. how do I turn 'aux' off? pressing the 'sux' button...
Simply plug the small USB key into your computer, turn on the SoundLink system and select your music--iTunes, Pandora®, whatever you like. That's it. No networks to configure, no cables to run. And you can control your music using the handy remote.
Remove the battery in the machine and put back. Also, remove the battery in the remote and insert a good battery.
To turn off youe aux simply press the aux botton on your phone i am sure it will work.
Thanks for contacting Fixya
Jul 04, 2010 | Bose SoundLink Wireless Music System...
Keyboard not working but mous is working
Sounds like the keybaord, mouse, and receiver are out of sync. Under the keyboard is the Connect button. Press it, then press the Connect button under the receiver that's connected to your computer. You may want to do the same with the mouse as well, just so all three components are properly sync'd at the same time.
If that doesn't do it, try reversing the order (receiver Connect, then the keyboard Connect button).
Aug 25, 2009 | Logitech Cordless MX 3200 Laser Mouse
The wireless logitech mouse was working properly until it has low battery, when I changed the battery, it doesn't work anymore. There's a light but it doesn't work.The battery that I used is newly charged....
You need to 'reconnect' it. You didn't specify the exact model of your wireless mouse, but most types have a special 'connect' button on the receiver-box of the wireless mouse or on the bottom-side of the mouse itself. Just press this 'connect' button and you should be fine ...
Aug 23, 2009 | Logitech Cordless Mouse
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard & mouse (S510) crashes my computer
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Logitech Wireless mouse.
As a rule the mouse is matched to the keyboard and a new mouse probably wouldn't work with the receiver.
Try this:
Oct 20, 2008 | Logitech Cordless Mouse
Wireless keyboard locked
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 26, 2008 | Logitech LX 700 9674180101
35 people viewed this question
 Grubhead
Grubhead
