Question about ATI Mobility RADEON Graphic Card
It did not work..T__T
Hello druid..
i had downloaded the catalyst but still it did not worked..
this is the error that had occurred..
could not load or assembly 'CLI.Implementation, Version=2.0.3009.39930, Culture=neutral,
PublicKeyToken=90Ba70f846762e'or one of its dependencies. The system cannot find file specified.
hope you could help me digure out my problem...
thanks..
still hoping,
abO
  • Anonymous Oct 20, 2008
    same problem vista utimate 32 with 3850
    President:
  • 2,712 Answers
Please download just the driver from HERE.
Don't install the Catalyst software. Your card should work with just the driver. Also make sure you have the latest version of DirectX.
BTW, which OS are you using? If you are using Vista, then you may find that this driver may not be compatible as it is for 2000/XP.
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    If you have Vista, try this link..
    http://www.omegadrivers.net/ati.php
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
How to fix Script Error "?"
Best would probably be to reinstall Catalyst Control Center, it controls the drivers for your Video card and configurations.
http://www.amd.com/en-gb/innovations/software-technologies/catalyst
At the end of the page you can download the software.
Jul 27, 2014 | Microsoft Windows 7 Ultimate for PC
Sapphire HD 7950 3G OC GDDR5. Update 13.4_w8 released Jul 9 2013 Display driver version Driver 12.104. source:...
Hello there!
There's not much need to worry if the device manager detects your card.
Yet,the catalyst installers are not too properly implemented.I recommend you to install stuff manually.In order to do this,ill divide the solution into a few parts:
Here we go!
1: Display drivers
Go to device manager > Display adapter > Right click card > Update driver > Browse manually > Have disk > Locate to your AMD/ATI folder where the catalyst installer is > Packages > Drivers > Display driver > Choose the first .inf > There you go,select your card,install it.
2: Applicants
Head to your AMD/ATI folder where you have the catalyst installer
Packages > Apps > Install all of these apps,it would be useful.
This would allow you to manually install the package,resulting in a non-error through the catalyst.
This error might be occuring because some of your apps/packages might be corrupted,the best solution is to install manually and find the culprit.Once done,google that app/package and download it.
I hope this helps you mayte.
Aug 27, 2013 | ATI Computers & Internet
Error occured during loading operation 80010514
Hello jesus_its_sp
This error means that the PS3 is unable to read the disc.
Does this error occur with other games? Has this game worked before?
The first thing you should try is cleaning the disc. Do this using a clean, dry cloth. Start from the centre of the disc and clean outwards.
Check for scratches. If the disc is damaged, you´ll need to purchase another disc.
If the problem persists, you may have a hardware problem.
Hope this helps. Good luck
ajblaj
Sep 13, 2010 | Dmm Call of Duty: World at War
Dell laptop DVD issue
If you have Vista OS, it could be a problem after installing ATI's Catalyst Software Suite. If you recently installed it, try uninstalling it or rolling it back to an older version.
Mar 20, 2010 | Dell Studio 1737 Laptop
Code Ld and sometimes Ob water doesn't seem to drain properly
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@&^$
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Error 5100 on PIXMA MP470
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Yellow question on sm bus controller, pci device and video controller
For Emachines W3503, download the chipset drivers for ATI Radeon® Xpress 200 at http://e4allupgraders.info/dir1/motherboards/socket775/D101GGC_downloads.shtml which provides all drivers for this model of computer.
This resolves Sm Bus Controller driver problem.
Also a good tool can be driver detective for emachines http://www.drivershq.com/Drivers/eMachines/W-Series/W3503/22605/22758/37169/Drivers.aspx
If you are recieving "Error 22: A critical error has occurred while initializing DirectDraw." while trying to play Diablo 2, Warcraft III, or World of Warcraft, it is because direct draw has been disabled. I reenabled mine by installing the catalyst at http://ati.amd.com/support/driver.html for Windows XP Media Center Edition - Radeon - Radeon X300 Series.. Then use the Catalyst Control Center to renable DirectDraw.
Jul 29, 2008 | E-Machines W3503 PC Desktop
DELL Vostro 1500 causing many problems...
For using xp you must have the correct drivers. These should be available for download from the Dell support website. You may also find updating windows xp will help you may be using service pack one, so make sure all updates are done.
If you have to load drivers you should load the chipset first followed by the graphics then the sound. Check on your hardware list under system in control panel that there are no conflicts.
I hope this is helpful please rate the assistance given.
Mar 29, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
52 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
