Question about Brother Lay-In Thread Serger Mechanical Sewing Machine
Where can I find sheap part for 1034D brother serger?
I need a part for a 1034D brother serger upper looper
  • nicoledawn Oct 09, 2008
    hi, i broke my upper looper on my brother 1034D and I am having the toughest time finding the part anywhere. I called a local shop and they can order it but it will take 2-3 weeks, I need it today for my business! Any suggestions???
  • Anonymous Mar 12, 2014
    upper looper is not catching thread on serger
    Problem Solver:
  • 3 Answers
Find a sew & vac shop near your house they usually have sewing machine parts
Posted on Jun 16, 2008
2 Suggested Answers
SOURCE: parts for 1034D brother serger
Cant find part for 1034D Tthread Tree Can you help
Posted on Mar 02, 2011
Brother overlock 1034d is not chaining. The upper looper is not passing far enough left to catch the left needle. Makes a "crunchy" sounds some times too.
First re-thread the machine starting with the upper looper(3), then lower looper(4), then the needles(2,1). If that doesn't fix it, it may be a matter of loosening the needle tension. Lastly slowly turn the handwheel and see where the loopers cross. The upper looper should come in just behind the scarf of the lower looper without any contact on the forward motion. Otherwise Your needlebar height could be off. Timing a serger is a very precise process and making adjustments could throw it out even further.
Dec 02, 2016 | Brother 1034D Mechanical Sewing Machine
Why does the upper looper thread keep busting?
Quite possibly the machine is not threaded correctly, the tension setting for that looper is too tight (could be the upper looper tension disk is stuck or dirty causing the thread to hang), or the thread is looped around something like the thread tree.
Replace the needles. Remove all the thread and re-thread from the beginning. Be sure to RAISE the presser foot before threading. Make sure to thread the threads in the correct order.
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Nov 01, 2015 | Brother 1034D Serger Sewing Machine
Knocking sound on brother 1034d brother serger
Stop using the machine. If your loopers are out of adjustment you will break them and increase your service cost by 3 times.
Aug 31, 2014 | Brother 1034D Serger Sewing Machine
Upper looper hits lower looper
The upper/lower looper need realignment, requires a qualified technician to do this.
Oct 21, 2013 | Brother 1034D Serger Sewing Machine
No chain forming on 1034d
You may have re-threaded in the wrong order. The correct order is upper looper, lower looper, right needle, left needle. So 3,4,2,1 (if numbering left to right)
Jul 23, 2012 | Brother 1034D Mechanical Sewing Machine
Hi i just got a new brother 1034D serger. And I'm
I found that I had to remove the stitch finger to thread the machine properly. Do remember to re-install it before starting to sew. If you are using 3-threads only, then remove and store the stitch finger.
Puzzled that this instruction is not in the threading section of the manual.
Jun 23, 2010 | Brother Lay-In Thread Serger Mechanical...
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Brother Lay-In Thread Serger Mechanical Sewing Machine Logo
247 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
