Question about Hoover Washing Machines
My Hoover 550 wil not stop filling with water
Possibly caused by a leaking water level sensor. Turn off the power, remove 3 screws at top back of control panel. Rotate the control panel forward and have a look at the white rubber hose on the left hand side. Check that it is connected at both ends and not perished. Also check that the adjuster cam (turn the level knob and look behind) is not broken.
Posted on Oct 28, 2010
My hoover 500mb 5.0kg washing machine fills up fine at start of cycle then just washes for a bit then just stats to fill up and wont stop till I stop it
I had a similar problem and not sure whether my solution would help you.It was to do with the position of the waste pipe.It should raised about 2ft. ,looped before discharged into the washing machine tee.when the discharge hose is lying on the floor there's a possibility that the water is filling up and going straight out.By raising it you are letting it fill up and presumably triggering the water level sensor.Hope this helps.
May 29, 2017 | Hoover Washing Machines
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
M hoover 550 is not pumping water in
No it is not. Capactors have nothing to do with inlet of water. Either the tap is off or the inlet valve is faulty. By the way it does not pump water in. It opens a valve & water just flows in under pressure from the tap
Jan 02, 2016 | Hoover Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Washing Machines Logo
247 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
