Question about Insignia IS-DVD1001 DVD Recorder/VCR
Dvd tray won't open
I can not get the tray door to open. When I push the button to open the door to insert disc the tray will not open. It says trying to read disc and says no disc is in the tray. I mannualy open the door and see a tiny black belt broken inside. Can you give me some advice of what to do and where to find a replacement belt. Also, Is this easy to fix yourself?
Try disconnecting power and then reconnect this happens to my unit often and this usually solves problem
Posted on Nov 29, 2008
    President:
  • 1,768 Answers
Call the manufacturer and ask where you can obtain the belt
it will probably be through a distributor in your area.
hope this helps.
Posted on May 22, 2008
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
Replace cd player
Apr 16, 2013 | Samsung Computers & Internet
I inserted a DVD wrong side into NEC TV NLT-!9HDDDV3. How do I remove it?
Mar 29, 2013 | Computers & Internet
Dell cd drive door won't open
CD/DVD Drive Tray problems
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
My dvd tray is not ejecting,i cannot insert a cd
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 05, 2013 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Inserted a DVD wrong way around (silver side facing towards us) now we can not ejecetd or play it.
Here are some options from best to worst and I recommend that you turn off the computer beforehand
Use a straightened paperclip and insert an end into the auto eject hole. (A little pinhole on the front of most disk drives)
Use a knife or flathead to pry the disk tray open.
If it doesn't have a tray you could use tweezers to pinch it out of there
I have pryed open disk trays before without issue
Mar 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Insignia IS-DVD1001 DVD Recorder/VCR Logo
406 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
